如何在Visual Studio 2005环境下用c语言调用ARM汇编,以便了解ARM指令
在网上找到了一个这样的例子,是Larry Bank写的。贴出来以供大家学习。让大家了解ARM汇编指令,并用vs2005进行调试跟踪。
工程是pocket pc 2003的工程,主要包含两个文件:main.c, armtest.asm。
对armtest.asm需要自定义编译选项,
命令行为 armasm -g armtest.asm
输出为   armtest.obj
源码如下:
main.c 源码
// Windows CE Sample Application
// Demonstrations how to use ARM assembly language within a C program
// Written by Larry Bank 3/25/2007
#include <windows.h>
int
iGlobal;
int
ARMTEST1(int,
int,
int
int);
* FUNCTION : WinMain(HANDLE, HANDLE, LPSTR, int)                                               *
* PURPOSE : Program entrypoint        * ****************************************************************************/
int
APIENTRY
WinMain
(HINSTANCE
hInstance,
HINSTANCE
hPrevInstance,
LPWSTR
lpCmdLine,
int
nCmdShow)
      int
iResult;
      TCHAR
szTemp[256];
      iGlobal
5;
      iResult
ARMTEST1(1,2,3,4);
      wsprintf(szTemp,
L"Result = %d",
iResult);
      MessageBox(HWND_DESKTOP,
szTemp,
L"ASM Result",
MB_OK);
     return
0;
/* WinMain() */
armtest.asm 源码:
; TITLE("Sample App")
     AREA
sample,
CODE,
READONLY
; name this block of code
     EXPORT
ARMTEST1
   IMPORT
iGlobal
; Called from C as int ARMTEST1(int, int, int, int);
; The first 4 parameters are passed in r0-r3, more parameters would be passed on the stack
ARMTEST1
proc
    add
r0,r0,r1
; add all of the inputs together
    add
r0,r0,r2
    add
r0,r0,r3
   ldr
r1,=iGlobal
; get the value of our global variable
      ldr
r1,[r1]
; dereference the pointer (I know there's a pipe stall here)
    add
r0,r0,r1
; we're not concerned with performance in this example
    mov
pc,lr
; return to C with the value in R0
     endp
     LTORG
; allow room for the address constant of our global (loaded relative to PC)
     END
继承事业,薪火相传
