ARM-S3C2440启动文件init.s解析(14)
;存储器控制寄存器的定义区
LTORG
SMRDATA DATA
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is  safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK<=75Mhz.
DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28)) ;各bank的bus width; 没有B0,因为由OM[1:0]pins 确定
DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC))  ;GCS0
DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC))  ;GCS1
DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC))  ;GCS2
DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC))  ;GCS3
DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC))  ;GCS4
DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC))  ;GCS5
DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))    ;GCS6   B6_MT定义在memcfg.inc中,11-->SDRAM
       ; B6_SCAN - 非reset 默认值
DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))    ;GCS7
DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)  ;Tchr- not used
;DCD 0x32     ;SCLK power saving mode, BANKSIZE 128M/128M
DCD 0x31     ;SCLK power saving mode, BANKSIZE 64M/64M
DCD 0x30     ;MRSR6 CL=3clk
DCD 0x30     ;MRSR7 CL=3clk
BaseOfROM  DCD |Image$$RO$$Base|
TopOfROM  DCD |Image$$RO$$Limit|
BaseOfBSS  DCD |Image$$RW$$Base|
BaseOfZero  DCD |Image$$ZI$$Base|
EndOfBSS  DCD |Image$$ZI$$Limit|
ALIGN
AREA RamData, DATA, READWRITE
^   _ISR_STARTADDRESS  ; _ISR_STARTADDRESS=0x33FF_FF00
HandleReset  #   4
HandleUndef  #   4
HandleSWI  #   4
HandlePabort    #   4
HandleDabort    #   4
HandleReserved  #   4
HandleIRQ  #   4
HandleFIQ  #   4
;Don't use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
;@0x33FF_FF20
HandleEINT0  #   4
HandleEINT1  #   4
HandleEINT2  #   4
HandleEINT3  #   4
HandleEINT4_7 #   4
HandleEINT8_23 #   4
HandleCAM  #   4  ; Added for 2440.
HandleBATFLT #   4
HandleTICK  #   4
HandleWDT  #   4
HandleTIMER0  #   4
HandleTIMER1  #   4
HandleTIMER2  #   4
HandleTIMER3  #   4
HandleTIMER4  #   4
HandleUART2   #   4
;@0x33FF_FF60
HandleLCD   #   4
HandleDMA0  #   4
HandleDMA1  #   4
HandleDMA2  #   4
HandleDMA3  #   4
HandleMMC  #   4
HandleSPI0  #   4
HandleUART1  #   4
HandleNFCON  #   4  ; Added for 2440.
HandleUSBD  #   4
HandleUSBH  #   4
HandleIIC  #   4
HandleUART0  #   4
HandleSPI1   #   4
HandleRTC   #   4
HandleADC   #   4
;@0x33FF_FFA0
END
继承事业,薪火相传
