arm内部寄存器读写函数(1)
arm内部寄存器读写函数(1)
1.在arch\parisc\include\asm\io.h中定义了如下函数:
以下函数用于内存映射
static inline void __iomem * ioremap(unsigned long offset, unsigned long size)
return __ioremap(offset, size, _PAGE_NO_CACHE);
#define ioremap_nocache(off, sz)
ioremap((off), (sz))
extern void iounmap(const volatile void __iomem *addr);
以下函数用于读写寄存器的值(数据寄存器,控制寄存器,配置寄存器...)
static inline unsigned char __raw_readb(const volatile void __iomem *addr)
return (*(volatile unsigned char __force *) (addr));
static inline unsigned short __raw_readw(const volatile void __iomem *addr)
return *(volatile unsigned short __force *) addr;
static inline unsigned int __raw_readl(const volatile void __iomem *addr)
return *(volatile unsigned int __force *) addr;
static inline unsigned long long __raw_readq(const volatile void __iomem *addr)
return *(volatile unsigned long long __force *) addr;
static inline void __raw_writeb(unsigned char b, volatile void __iomem *addr)
*(volatile unsigned char __force *) addr = b;
static inline void __raw_writew(unsigned short b, volatile void __iomem *addr)
*(volatile unsigned short __force *) addr = b;
static inline void __raw_writel(unsigned int b, volatile void __iomem *addr)
*(volatile unsigned int __force *) addr = b;
static inline void __raw_writeq(unsigned long long b, volatile void __iomem *addr)
*(volatile unsigned long long __force *) addr = b;
static inline unsigned char readb(const volatile void __iomem *addr)
return __raw_readb(addr);
static inline unsigned short readw(const volatile void __iomem *addr)
return le16_to_cpu(__raw_readw(addr));
static inline unsigned int readl(const volatile void __iomem *addr)
return le32_to_cpu(__raw_readl(addr));
static inline unsigned long long readq(const volatile void __iomem *addr)
return le64_to_cpu(__raw_readq(addr));
static inline void writeb(unsigned char b, volatile void __iomem *addr)
__raw_writeb(b, addr);
static inline void writew(unsigned short w, volatile void __iomem *addr)
__raw_writew(cpu_to_le16(w), addr);
static inline void writel(unsigned int l, volatile void __iomem *addr)
__raw_writel(cpu_to_le32(l), addr);
static inline void writeq(unsigned long long q, volatile void __iomem *addr)
__raw_writeq(cpu_to_le64(q), addr);
2.samsung.h中对串口对应寄存器的读写控制具体实现:
#define portaddr(port, reg) ((port)->membase + (reg))
#define rd_regb(port, reg) (__raw_readb(portaddr(port, reg)))
struct uart_port {
spinlock_t
lock;
/* port lock */
unsigned long
iobase;
/* in/out[bwl] */
unsigned char __iomem
*membase;
/* read/write[bwl] */
unsigned int
(*serial_in)(struct uart_port *, int);
void
(*serial_out)(struct uart_port *, int, int);
unsigned int
irq;
/* irq number */
unsigned long
irqflags;
/* irq flags  */
unsigned int
uartclk;
/* base uart clock */
unsigned int
fifosize;
/* tx fifo size */
unsigned char
x_char;
/* xon/xoff char */
unsigned char
regshift;
/* reg offset shift */
unsigned char
iotype;
/* io access style */
unsigned char
unused1;
继承事业,薪火相传
