【晒FRAM铁电存储器样片】+使用ATMEL Mega16读写MB85RC256V
主控MCU是ATMEL Mega16,主频8MHz,使用硬件I2C(ATMEL叫TWI)。标准的I2C电路,电路图我就不给出了。当电压为5V时, 上拉电阻为10K时, SCL和SDA的一个时钟周期为10us; 上拉电阻为1K时, SCL和SDA的一个时钟周期为2.5us。兼容多种容量的EEPROM.
#include<iom16v.h>
#include<macros.h>
#include"xd.h"
#define XDmain
#include"xdprj.h"
uchar r_buf[64];
uchar w_buf[64];
void main()
uint i;
uchar *r;
uint b;
uint c;
uchar *w;
uint x;
uint y;
tms(100);
//-----初始化cpu------
setreg_m16();
//初始化cpu
for(i=0;i<64;i++)
//清主机读和写缓存区
r_buf=w_buf=0;
for(i=0;i<64;i++)
//写缓存区赋初值
w_buf=i;
r=r_buf;
//读参数
b=0x00;
c=64;
w=w_buf;
//写参数
x=0x00;
y=64;
wt24c(w,x,y);
//写
rd24c(r,b,c);
//读
//-----读出的数据发送到PC-----
for(i=0;i<64;i++)
txd_buf=r_buf;
txd_buf[69]=syserr;
txdpo(txd_buf, 69);
while(1);
c=0;
//ICC-AVR application builder : 2005-11-9 22:09:34
// Target : M16
// Crystal: 8.0000Mhz
void port_init(void)
PORTA = 0xFF;
DDRA = 0x00;
PORTB = 0xFF;
DDRB = 0x00;
PORTC = 0xFF; //m103 output only
DDRC = 0x00;
PORTD = 0xFF;
DDRD = 0x00;
//TWI initialize
// bit rate:100
void twi_init(void)
TWCR= 0X00; //disable twi
TWBR= 0x64; //set bit rate
TWSR= 0x00; //set prescale
TWAR= 0x00; //set slave address
TWCR= 0x04; //enable twi
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9615 (0.2%)
// char size: 8 bit
// parity: Disabled
void uart0_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = BIT(URSEL) | 0x06;
UBRRL = 0x33; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0x08;
//call this routine to initialize all peripherals
void setreg_m16(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
twi_init();
uart0_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
1# fanglirong
#include<iom128v.h>
#include<macros.h>
#include"xd.h"
#include"xdprj.h"
//------在此设定芯片型号------
#define e2prom 32
// <---在此设定芯片型号, 1代表24C01; 16代表24C16; 512代表24C512
#if e2prom==1
#define PAGE_SIZE 8
#define PAGE_EXP 3
#define SIZE 0x007f
#elif e2prom==2
#define PAGE_SIZE 8
#define PAGE_EXP 3
#define SIZE 0x00ff
#elif e2prom==4
#define PAGE_SIZE 16
#define PAGE_EXP 4
#define SIZE 0x01ff
#elif e2prom==8
#define PAGE_EXP 4
#define SIZE 0x03ff
#elif e2prom==16
#define PAGE_EXP 4
#define SIZE 0x07ff
#elif e2prom==32
#define PAGE_SIZE 32
#define PAGE_EXP 5
#define SIZE 0x0fff
#elif e2prom==64
#define PAGE_EXP 5
#define SIZE 0x1fff
#elif e2prom==128
#define PAGE_SIZE 64
#define PAGE_EXP 6
#define SIZE 0x3fff
#elif e2prom==256
#define PAGE_EXP 6
#define SIZE 0x7fff
#elif e2prom==512
#define PAGE_SIZE 128
#define PAGE_EXP 7
#define SIZE 0xffff
#endif
//--------在此设定芯片地址-------
#define W_ADD_COM 0xa0
//写字节命令及器件地址(根据地址实际情况改变), 1010 A2 A1 A0 0
#define R_ADD_COM 0xa1
//读命令字节及器件地址(根据地址实际情况改变), 1010 A2 A1 A0 1
#define SLAW
0x18
//SLA_W 已正常发送代码,判断器件是否正常应答的常量.
//-----在此改变预置错误号-----
#define ERR_SLAW
ERR_10
//写字节命令及器件地址错, 在此也就是读写器件错!!
//-----------4个I2总线公用函数, 可供其它I2总线器件的程序调用--------------
void i2cstart(void);
//总线上起动开始条件
uchar i2cwt(uchar a);
//把一个字节数据输入器件, 返回TWI状态
uchar i2crd(void);
//i2c读要调用的函数
void i2cstop(void);
//总线上起动停止条件
uchar * wt24c_fc(uchar *p, uint ad, uchar n);
//向24Cxx写入数据wt24c_h()所要调用的函数
//向24Cxx写入数据
//参数: *p_rsc要输出数据的主机内存地址指针; ad_dst要写入数据的i2c的地址(双字节); num数据个数
//参数条件: ad_dst: ad_dst+(num-1)不能大于器件的最高地址; num必须>0;
void wt24c(uchar *p_rsc, uint ad_dst, uint num)
{ uint n;
n=ad_dst/PAGE_SIZE;
//确定地址与块地址的差
if(n) n=(ulong)PAGE_SIZE*(n+1)-ad_dst;
else n=PAGE_SIZE-ad_dst;
if(n>=num)
//如果ad_dst所在的数据块的末尾地址 >= ad_dst + num, 就直接写入num个数据
wt24c_fc(p_rsc, ad_dst, num);
if(syserr!=0) return;
else
//如果ad_dst所在的数据块末尾地址 < ad_dst + num, 就先写入ad_dst所在的数据块末尾地址与 ad_dst 之差个数据
{ p_rsc=wt24c_fc(p_rsc, ad_dst, n);
num-=n; //更新剩下数据个数
ad_dst+=n;
//更新剩下数据的起始地址
//把剩下数据写入器件
while(num>=PAGE_SIZE)
//先按PAGE_SIZE为长度一页一页的写入
p_rsc=wt24c_fc(p_rsc, ad_dst, PAGE_SIZE);
num-=PAGE_SIZE;
//更新剩余数据个数
ad_dst+=PAGE_SIZE;
//更新剩下数据的起始地址
if(num)
//把最后剩下的小于一个PAGE_SIZE长度的数据写入器件
//从24cxx读出数据
//参数: *p_dst要读入数据的主机内存地址指针; ad_rsc要输出数据的i2c的地址(整形); num数据个数(整形)
//参数条件: ad_dst+(num-1)不能大于器件的最高地址; num必须>0;
void rd24c(uchar *p_dst, uint ad_rsc, uint num)
{ uchar t=0;
#if e2prom<32
t=ad_rsc>>8;
t<<=1;
#endif
i2cstart();
//发送起始信号
if(i2cwt(W_ADD_COM+t)==SLAW)//发送SLA_W, 写字节命令及器件地址
#if e2prom>16
i2cwt(ad_rsc>>8);
//ad_rsc的高位, 发送要读出数据的地址
#endif
i2cwt(ad_rsc);
//ad_rsc的低位
i2cstart();
//再发送起始信号
i2cwt(R_ADD_COM+t);
//发送SLA_R, 读命令字节及器件地址
for(;num>0;num--)
{ *p_dst=i2crd();
//从器件读出一个字节
p_dst++;
else syserr=ERR_SLAW;
//写字节命令及器件地址错或对方无应答
i2cstop();
//返回写入n个字节后的主机内存指针
uchar t=0;
#if e2prom<32
t=ad>>8;
t<<=1;
#endif
i2cstart();
//发送起始信号
#if e2prom>16
i2cwt(ad>>8);
//ad_dst的高位到器件
#endif
i2cwt(ad);
//ad_dst的低位到器件
for(;n>0;n--)
//发送要写入的数据
{ i2cwt(*p);
p++;
//写字节命令及器件地址错
i2cstop();
tms(6);
//延时6ms
return(p);
//-------------------------------以下为其它I2总线器件可调用的函数--------------------------
//总线上起动开始条件
void i2cstart(void)
TWCR= BIT(TWINT) | BIT(TWSTA) | BIT(TWEN);
while (!(TWCR & BIT(TWINT)));
TWDR = a;
TWCR = BIT(TWINT) | BIT(TWEN);
_NOP();
return(TWSR&0b11111000);
//i2c读要调用的函数
//从器件读出一个字节
uchar i2crd(void)
TWCR= BIT(TWINT) | BIT(TWEA) | BIT(TWEN);
return(TWDR);
//总线上起动停止条件
void i2cstop(void)
TWCR = BIT(TWINT) | BIT(TWSTO) | BIT(TWEN);
