【晒FRAM铁电存储器样片】+ MB85RS64 试用心得之二:开始写程序
使用MSP430单片机,以 IO模拟方式驱动MB85RS64,可以正确读写MB85RS64,程序如下: #include "Main.h"
CS----P2.0
SO----P2.1
SI----P2.2
CLK---P2.3
CS----P1.0
WP----P1.5
HOLD--P1.6
#define MB85RS64_CS_L P1OUT |= BIT0
#define MB85RS64_CS_H P1OUT &= ~BIT0
#define MB85RS64_WP_L P1OUT |= BIT5
#define MB85RS64_WP_H P1OUT &= ~BIT5
#define MB85RS64_HOLD_L P1OUT |= BIT6
#define MB85RS64_HOLD_H P1OUT &= ~BIT6
void LEDOn(unsigned int cnt);
//寄存器相关
#define MB85RS64_WREN 0x06//Set Write Enable Latch 0000 0110
#define MB85RS64_WRDI 0x04//Reset Write Enable Latch 0000 0100B
#define MB85RS64_RDSR 0x05//Read Status Register 0000 0101B
#define MB85RS64_WRSR 0x01//Write Status Register 0000 0001B
#define MB85RS64_READ 0x03//Read Memory Code 0000 0011B
#define MB85RS64_WRITE 0x02//Write Memory Code 0000 0010B
void Init_uart0()
UCA0CTL1|=UCSWRST;
UCA0CTL0&=~UC7BIT;//字符长度为8
UCA0CTL1|=UCSSEL_2;//选择系统时钟
UCA0BR0=0x6D; //波特率为9600
UCA0BR1=0;
UCA0MCTL=0;//UCA0MCTL=UCBRS0;
IE2=UCA0RXIE+UCA0TXIE;//开接收使能
UCA0CTL1&=~UCSWRST;
P1SEL|=BIT1+BIT2; //将P1.1 P1.2设为第二功能
P1SEL2|=BIT1+BIT2;
void sendChar(unsigned char c)
while(!(IFG2&UCA0TXIFG));
UCA0TXBUF=c;
void sendStr(unsigned char *s)
while(*s!='\0')
sendChar(*s);
s++;
void main(void)
volatile unsigned int i;
char uart_tx_buf[30];
unsigned char rd_data;
unsigned char rd;
unsigned char rd_test = 0;
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
P1OUT = 0x00; // P1 setup for LED & reset output
P1DIR |= BIT0 + BIT5; //
P1SEL = BIT1 + BIT2 + BIT4;
P1SEL2 = BIT1 + BIT2 + BIT4;
UCA0CTL0 |= UCCKPL + UCMSB + UCMST + UCSYNC; // 3-pin, 8-bit SPI master
UCA0CTL1 |= UCSSEL_2; // SMCLK
UCA0BR0 |= 0x02; // /2
UCA0BR1 = 0; //
UCA0MCTL = 0; // No modulation
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
//IE2 |= UCA0RXIE; // Enable USCI0 RX interrupt
Init_uart0();
sendStr("Init\n");
while(1)
CLR_MB85RS64_CS;
Write(MB85RS64_WREN);
SET_MB85RS64_CS;
//Read
CLR_MB85RS64_CS;
Write(MB85RS64_RDSR);
rd_data=Read();
SET_MB85RS64_CS;
sprintf(uart_tx_buf,"stat1==0x%02X\n",rd_data);
sendStr(uart_tx_buf);
CLR_MB85RS64_CS;
Write(MB85RS64_WRDI);
SET_MB85RS64_CS;
//Read
CLR_MB85RS64_CS;
rd_data=Read();
SET_MB85RS64_CS;
DelayXms(1000);
while(1)
//Read_data(0,&rd,1);
//sprintf(uart_tx_buf,"rd=0x%02X\n",rd);
//sendStr(uart_tx_buf);
Write_data(0,&rd_test,1);
rd_test++;
Read_data(0,&rd,1);
DelayXms(1000);
while(1)
CLR_MB85RS64_CS;
SET_MB85RS64_CS;
//Write Memory Code
CLR_MB85RS64_CS;
Write(MB85RS64_WRITE);
Write(0x00);
Write(0x00);
Write(rd_test);
rd_test++;
SET_MB85RS64_CS;
//Read
CLR_MB85RS64_CS;
Write(MB85RS64_READ);
Write(0x00);
Write(0x00);
rd_data=Read();
SET_MB85RS64_CS;
sprintf(uart_tx_buf,"rd=0x%02X\n",rd_data);
DelayXms(1000);
/*while(1)
CLR_MB85RS64_CS;
stat=Read();
SET_MB85RS64_CS;
sprintf(uart_tx_buf,"stat=%02X\n",stat);
//printf("%02X\n",stat);
DelayXms(100);
CLR_MB85RS64_CS;
SET_MB85RS64_CS;
CLR_MB85RS64_CS;
stat=Read();
SET_MB85RS64_CS;
sprintf(uart_tx_buf,"stat222=%02X\n",stat);
DelayXms(100);
CLR_MB85RS64_CS;
Write(MB85RS64_WRSR);
Write(0x00);
SET_MB85RS64_CS;
CLR_MB85RS64_CS;
stat=Read();
SET_MB85RS64_CS;
sendStr("NEXT\n\n");
DelayXms(3000);
Test();
while(1)
CLR_MB85RS64_CS;DelayXms(1000);
SET_MB85RS64_CS;DelayXms(1000);
while (!(IFG2&UCA0RXIFG));
temp = UCA0RXBUF;
