» 从ISE启动ModelSim时遇到的问题
pengpengpang
(pengpengpang)
来自
中国
156 小时
来自
中国
pengpengpang
发表于 2014-8-22 19:37
Design
Windows
解决方法:
1〉从Windows的Start Menu开始,Xilinx ISE Design Suite 13.4 —〉EDK —〉Tools —〉Compile Simulation Libraries
2〉从Process菜单,选择Process Properties...,设置Compiled Libraey Directory
3〉set the Enviroment variables(
http://forums.xilinx.com/t5/Inst ... -library/td-p/72635
- MODELSIM environment variable to point to the modelsim.ini file
- WD_MGC environment variable to point to the directory containing the modelsim.ini file
4〉复制Xilinx\13.4\ISE_DS\EDK\modelsim.ini里的[Library]节中的下列行到到modeltech_10.1b\modelsim.ini里的[Library]节下
secureip = D:\Xilinx\13.4\ISE_DS\EDK/secureip
unisim = D:\Xilinx\13.4\ISE_DS\EDK/unisim
unimacro = D:\Xilinx\13.4\ISE_DS\EDK/unimacro
unisims_ver = D:\Xilinx\13.4\ISE_DS\EDK/unisims_ver
unimacro_ver = D:\Xilinx\13.4\ISE_DS\EDK/unimacro_ver
simprim = D:\Xilinx\13.4\ISE_DS\EDK/simprim
simprims_ver = D:\Xilinx\13.4\ISE_DS\EDK/simprims_ver
xilinxcorelib = D:\Xilinx\13.4\ISE_DS\EDK/xilinxcorelib
xilinxcorelib_ver = D:\Xilinx\13.4\ISE_DS\EDK/xilinxcorelib_ver
uni9000_ver = D:\Xilinx\13.4\ISE_DS\EDK/uni9000_ver
cpld = D:\Xilinx\13.4\ISE_DS\EDK/cpld
cpld_ver = D:\Xilinx\13.4\ISE_DS\EDK/cpld_ver
edk = D:\Xilinx\13.4\ISE_DS\EDK/edk
来源:
天天のLINK
的博客
