u16 FSMC_NOR_ReadHalfWord(u32 ReadAddr)
NOR_WRITE(ADDR_SHIFT(0x005555), 0x00AA);
NOR_WRITE(ADDR_SHIFT(0x002AAA), 0x0055);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0 );return (*(vu16 *)((Bank1_NOR2_ADDR + ReadAddr)));
* Function Name : FSMC_NOR_ReadBuffer
* Description : Reads a block of data from the FSMC NOR memory.
* Input : - pBuffer : pointer to the buffer that receives the data read
* from the NOR memory.
* - ReadAddr : NOR memory internal address to read from.
* - NumHalfwordToRead : number of Half word to read.
* Output : None
* Return : None
void FSMC_NOR_ReadBuffer(u16* pBuffer, u32 ReadAddr, u32 NumHalfwordToRead)
NOR_WRITE(ADDR_SHIFT(0x05555), 0x00AA);
NOR_WRITE(ADDR_SHIFT(0x02AAA), 0x0055);
NOR_WRITE((Bank1_NOR2_ADDR + ReadAddr), 0x00F0);
for(; NumHalfwordToRead != 0x00; NumHalfwordToRead--) /* while there is data to read */
/* Read a Halfword from the NOR */
*pBuffer++ = *(vu16 *)((Bank1_NOR2_ADDR + ReadAddr));
ReadAddr = ReadAddr + 2;
* Function Name : FSMC_NOR_ReturnToReadMode
* Description : Returns the NOR memory to Read mode.
* Input : None
* Output : None
* Return : NOR_SUCCESS
NOR_Status FSMC_NOR_ReturnToReadMode(void)
NOR_WRITE(Bank1_NOR2_ADDR, 0x00F0);
return (NOR_SUCCESS);
* Function Name : FSMC_NOR_Reset
* Description : Returns the NOR memory to Read mode and resets the errors in
* the NOR memory Status Register.
* Input : None
* Output : None
NOR_Status FSMC_NOR_Reset(void)
* Function Name : FSMC_NOR_GetStatus
* Description : Returns the NOR operation status.
* Input : - Timeout: NOR progamming Timeout
* Output : None
* Return : NOR_Status:The returned value can be: NOR_SUCCESS, NOR_ERROR
* or NOR_TIMEOUT |
