STM32-FSMC-NOR FLASH (11)
2.main.c
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "fsmc_nor.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define BUFFER_SIZE 0x400
#define WRITE_READ_ADDR 0x8000
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
ErrorStatus HSEStartUpStatus;
u16 TxBuffer[BUFFER_SIZE];
u16 RxBuffer[BUFFER_SIZE];
u32 WriteReadStatus = 0, Index = 0;
NOR_IDTypeDef NOR_ID;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Fill_Buffer(u16 *pBuffer, u16 BufferLenght, u32 Offset);
/* Private functions ---------------------------------------------------------*/
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
/* System Clocks Configuration */
RCC_Configuration();
/* NVIC Configuration */
NVIC_Configuration();
/* PF.06 and PF.07 config to drive LD1 and LD2 *****************************/
/* Enable GPIOF clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF, ENABLE);
/* Configure PF.06 and PF.07 as Output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOF, &GPIO_InitStructure); |
