pr_debug("s3c2410_rtc: tick irq %d, alarm irq %d\n",
s3c_rtc_tickno, s3c_rtc_alarmno);
/* get the memory region */
res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
if (res == NULL) {
dev_err(&pdev->dev, "failed to get memory region resource\n");
return -ENOENT;
s3c_rtc_mem = request_mem_region(res->start,
res->end-res->start+1,
pdev->name);
if (s3c_rtc_mem == NULL) {
dev_err(&pdev->dev, "failed to reserve memory region\n");
ret = -ENOENT;
goto err_nores;
s3c_rtc_base = ioremap(res->start, res->end - res->start + 1);
if (s3c_rtc_base == NULL) {
dev_err(&pdev->dev, "failed ioremap()\n");
ret = -EINVAL;
goto err_nomap;
/* check to see if everything is setup correctly */
s3c_rtc_enable(pdev, 1);
pr_debug("s3c2410_rtc: RTCCON=%02x\n",
readb(s3c_rtc_base + S3C2410_RTCCON));
s3c_rtc_setfreq(&pdev->dev, 1);
device_init_wakeup(&pdev->dev, 1);
/* register RTC and exit */
rtc = rtc_device_register("s3c", &pdev->dev, &s3c_rtcops,
THIS_MODULE);
if (IS_ERR(rtc)) {
dev_err(&pdev->dev, "cannot attach rtc\n");
ret = PTR_ERR(rtc);
goto err_nortc;
rtc->max_user_freq = 128;
platform_set_drvdata(pdev, rtc);
return 0;
err_nortc:
s3c_rtc_enable(pdev, 0);
iounmap(s3c_rtc_base);
err_nomap:
release_resource(s3c_rtc_mem);
err_nores:
return ret;
