s3c2410_cpu_suspend(regs_save); //调用汇编函数s3c2410_cpu_suspend 进入sleep。
上为进入休眠部分,下为唤醒部分。
cpu_init(); //CPU初始化
tmp = __raw_readl(S3C2410_GSTATUS2);
tmp &= S3C2410_GSTATUS2_OFFRESET;
__raw_writel(tmp, S3C2410_GSTATUS2); //清除唤醒复位标记
s3c2410_pm_do_restore_core(core_save, ARRAY_SIZE(core_save)); //恢复核心配置
s3c2410_pm_do_restore(gpio_save, ARRAY_SIZE(gpio_save)); //恢复io口配置
s3c2410_pm_do_restore(irq_save, ARRAY_SIZE(irq_save)); //恢复中断配置
s3c2410_pm_do_restore(uart_save, ARRAY_SIZE(uart_save)); //恢复串口配置
s3c2410_pm_debug_init(); //串口调试函数初始化
DBG("post sleep: IRQs 0x%08x, 0x%08x\n",
__raw_readl(S3C2410_SRCPND),
__raw_readl(S3C2410_EINTPEND)); //打印信息
s3c2410_pm_show_resume_irqs(IRQ_EINT0, __raw_readl(S3C2410_SRCPND),
s3c_irqwake_intmask); //查看中断唤醒源信息
s3c2410_pm_show_resume_irqs(IRQ_EINT4-4, __raw_readl(S3C2410_EINTPEND),
s3c_irqwake_eintmask); //查看中断唤醒源信息
DBG("post sleep, preparing to return\n");
s3c2410_pm_check_restore();//如果需要在sleep前检查ram则此函数会运行,否则此函数为空,即如果CONFIG_S3C2410_PM_CHECK被定义。
DBG("S3C2410 PM Resume (post-restore)\n");
return 0;
5. 进休眠前的最后汇编段程序(arch/arm/mach-s3c2410/sleep.s)
ENTRY(s3c2410_cpu_suspend)
stmfd sp!, { r4 - r12, lr }
@@ store co-processor registers
mrc p15, 0, r4, c15, c1, 0 @ CP access register
mrc p15, 0, r5, c13, c0, 0 @ PID
mrc p15, 0, r6, c3, c0, 0 @ Domain ID
mrc p15, 0, r7, c2, c0, 0 @ translation table base address
mrc p15, 0, r8, c1, c0, 0 @ control register
stmia r0, { r4 - r13 }
@@ flush the caches to ensure everything is back out to
@@ SDRAM before the core powers down
#ifndef CONFIG_CPU_DCACHE_WRITETHROUGH
bl arm920_flush_kern_cache_all
#endif
@@ prepare cpu to sleep
ldr r4, =S3C2410_REFRESH
ldr r5, =S3C24XX_MISCCR
ldr r6, =S3C2410_CLKCON
ldr r7, [ r4 ] @ get REFRESH (and ensure in TLB)
ldr r8, [ r5 ] @ get MISCCR (and ensure in TLB)
ldr r9, [ r6 ] @ get CLKCON (and ensure in TLB)
orr r7, r7, #S3C2410_REFRESH_SELF @ SDRAM sleep command
orr r8, r8, #(S3C2410_MISCCR_USBSUSPND0 | S3C2410_MISCCR_USBSUSPND1) @suspend usb
orr r8, r8, #(S3C2400_MISCCR_SPUCR_LDIS | S3C2400_MISCCR_SPUCR_HDIS) @suspend d(0-31)
orr r8, r8, #S3C2410_MISCCR_SDSLEEP @ SDRAM power-down signals
orr r9, r9, #S3C2410_CLKCON_POWER @ power down command
teq pc, #0 @ first as a trial-run to load cache
bl s3c2410_do_sleep
teq r0, r0 @ now do it for real
b s3c2410_do_sleep @
@@ align next bit of code to cache line
.align 8
s3c2410_do_sleep:
streq r7, [ r4 ] @ SDRAM sleep command
mov r0, #0x1000
1: subs r0, r0, #1 @wait until the SelfRefresh is released
bne 1b
streq r8, [ r5 ] @ SDRAM power-down config
streq r9, [ r6 ] @ CPU sleep
1: beq 1b
mov pc, r14
2、唤醒部分
1、Uboot部分(u-boot-1.1.4/cpu/arm920t/start.s)
reset:
#if 0
mrs r0, cpsr /* Set the cpu to SVC32 mode */
bic r0, r0, #0x1f
orr r0, r0, #0xd3
msr cpsr, r0
#endif
/* disable watchdog timer */
mov r0, #WTCON_BASE
ldr r1, =0x0
str r1, [r0, #oWTCON]
* mask all IRQs by setting all bits in the INTMR - default
mov r0, #INT_BASE
ldr r1, =0xffffffff
str r1, [r0, #oINTMSK]
ldr r1, =0x7ff
str r1, [r0, #oINTSUBMSK]
mov r0, #CLK_BASE
ldr r1, =0xffffffff
str r1, [r0, #oLOCKTIME]
/* FCLK:HCLK CLK */
ldr r1, =0x0
str r1, [r0, #oCAMDIVN]
ldr r1, =_clkdivn
str r1, [r0, #oCLKDIVN]
mrc p15, 0, r1, c1, c0, 0 /* read ctrl register */
orr r1, r1, #0xc0000000 /* Asynchronous */
mcr p15, 0, r1, c1, c0, 0 /* write ctrl register */
/* UPLL setup */
ldr r1, =_upllcon
str r1, [r0, #oUPLLCON] |
