原文链接:http://blog.csdn.net/ywhfdl/article/details/74956151、学verilog 一个月了,在开发板上面写了很多代码,但是始终对一些问题理解的不够透彻,这里我们来写几个例子仿真出阻塞和非阻塞的区别,我们先上代码module LED ( CLK, RSTn, scan, flag , c, ,one,two,three,four); input CLK; input RSTn; input scan; output flag,c; output [3:0] one,two,three,four;/***********************************************************/ reg F1,F2; reg a,b; reg [3:0] one,two,three,four; /********************信号传递之间的非阻塞赋值***************************************/ always @ ( posedge CLK or negedge RSTn ) // if( !RSTn ) begin F1 <= 1'b1; F2 <= 1'b1; end else begin F1 <= scan; F2 <= F1; end /*******************信号传递之间的阻塞赋值****************************************/ always @ ( posedge CLK or negedge RSTn ) // if( !RSTn ) begin a = 1'b1; b = 1'b1; end else begin a = scan; b = a; end /******************数据加 非阻塞赋值 先判断后计数*****************************************/ always @ ( posedge CLK or negedge RSTn ) //one <= if( !RSTn ) begin one<=0; end else begin if(one==14) one<=0; else one<=one+1; end/***************数据加 非阻塞赋值 先计数后判断********************************************/ always @ ( posedge CLK or negedge RSTn ) // two<= if( !RSTn ) begin two<=0; end else begin two<=two+1; if(two==14) two<=0; end /**************数据加 阻塞赋值 先判断后计数*********************************************/ always @ ( posedge CLK or negedge RSTn ) //three = if( !RSTn ) begin three=0; end else begin if(three==14) three=0; else three=three+1; end/*************数据加 阻塞赋值 先计数后判断**********************************************/ always @ ( posedge CLK or negedge RSTn ) //four = if( !RSTn ) begin four=0; end else begin four=four+1; if(four==14) four=0; end /****************信号之间传递***********************/ assign flag = F2 & !F1;assign c = b & !a;/***************************************/ endmodule 2、我使用modesim 仿真,下面为我的 test bench `timescale 1 ps/ 1 psmodule LED_vlg_tst();// constants // general purpose registersreg eachvec;// test vector input registersreg CLK;reg RSTn;reg scan;// wires wire c;wire flag;wire [3:0] four;wire [3:0] one;wire [3:0] three;wire [3:0] two;// assign statements (if any) LED i1 (// port map - connection between master ports and signals/registers .CLK(CLK), .RSTn(RSTn), .c(c), .flag(flag), .four(four), .one(one), .scan(scan), .three(three), .two(two));/*initial begin // code that executes only once // insert code here --> begin // --> end $display("Running testbench"); end always // optional sensitivity list // @(event1 or event2 or .... eventn) begin // code executes for every event on sensitivity list // insert code here --> begin @eachvec; // --> end end endmodule*/initial beginCLK = 0;forever#10 CLK = ~CLK; endinitial beginscan = 0;forever#100 scan = ~scan; endinitial beginRSTn = 0;#1000 RSTn = 1;#1000;#1000;#1000;#1000;#1000;#1000;#1000;#1000;$stop;endendmodule 主要就是初始化一个CLK 和scan的信号,然后就是初始化一下复位,最后就是设置仿真时间,这样modesim 就不会一直处于仿真状态,消耗资源,也可以方便仿真。 其中quartus 与modesim 互相调用调试,可以关注我的博客,这里我就不具体讲解了! 3、modesim 波形图 大家注意到红线框内的数据变化,就能很清楚的理解 阻塞与非阻塞了! 微观分析 阻塞与非阻塞1、上代码,具体观察,a,b,c与F1,F2,flage 的变化 module LED ( CLK, RSTn, scan, flag , a,b,c,F1,F2,); input CLK; input RSTn; input scan; output flag,a,b,c; output F1,F2;/***********************************************************/ reg F1,F2; reg a,b; /***********************************************************/ always @ ( posedge CLK or negedge RSTn ) // if( !RSTn ) begin F1 <= 1'b1; F2 <= 1'b1; end else begin F1 <= scan; F2 <= F1; end /***********************************************************/ always @ ( posedge CLK or negedge RSTn ) // if( !RSTn ) begin a = 1'b1; b = 1'b1; end else begin a = scan; b = a; end /***********************************************************/ assign flag = F2 & !F1;assign c = b & !a;/***************************************/ endmodule 代码涵义就不讲解了 2、test bench 代码,与上面相同,这里不重复了
3、上图 看波形
