ARM做为USB从设备的实现(4)
ARM做为USB从设备的实现(4)
  • /****************************** Configurations ******************************/
  • static
    int __init do_config(struct usb_configuration *c)
  •     struct hidg_func_node *e;
  •     int func = 0, status = 0;
  •     if (gadget_is_otg(c->cdev->gadget)) {
  •         c->descriptors = otg_desc;
  •         c->bmAttributes |= USB_CONFIG_ATT_WAKEUP;
  •     list_for_each_entry(e, &hidg_func_list, node) {
  •         status = hidg_bind_config(c, e->func, func++);
  •         if (status)
  •             break;
  •     return status;
  • static
    struct usb_configuration config_driver = {
  •     .label          = "HID Gadget",
  •     .bind           = do_config,
  •     .bConfigurationValue    = 1,
  •     /* .iConfiguration = DYNAMIC */
  •     .bmAttributes       = USB_CONFIG_ATT_SELFPOWER,
  • /****************************** Gadget Bind ******************************/
  • static
    int __init hid_bind(struct usb_composite_dev *cdev)
  •     struct usb_gadget *gadget = cdev->gadget;
  •     struct list_head *tmp;
  •     int status, gcnum, funcs = 0;
  •     list_for_each(tmp, &hidg_func_list)
  •         funcs++;
  •     if (!funcs)
  •         return -ENODEV;
  •     /* set up HID */
  •     printk("=============bind\n");
  •     status = ghid_setup(cdev->gadget, funcs);
  •     if (status < 0)
  •         return status;
  •     gcnum = usb_gadget_controller_number(gadget);
  •     if (gcnum >= 0)
  •         device_desc.bcdDevice = cpu_to_le16(0x0300 | gcnum);
  •     else
  •         device_desc.bcdDevice = cpu_to_le16(0x0300 | 0x0099);
  •     /* Allocate string descriptor numbers ... note that string
  •      * contents can be overridden by the composite_dev glue.
  •     /* device descriptor strings: manufacturer, product */
  •     snprintf(manufacturer, sizeof manufacturer, "%s %s with %s",
  •         init_utsname()->sysname, init_utsname()->release,
  •         gadget->name);
  •     status = usb_string_id(cdev);
  •     if (status < 0)
  •         return status;
  •     strings_dev[STRING_MANUFACTURER_IDX].id = status;
  •     device_desc.iManufacturer = status;
  •     if (status < 0)
  •         return status;
  •     strings_dev[STRING_PRODUCT_IDX].id = status;
  •     device_desc.iProduct = status;
  •     /* register our configuration */
  •     status = usb_add_config(cdev, &config_driver);
  •     if (status < 0)
  •         return status;
  •     dev_info(&gadget->dev, DRIVER_DESC ", version: " DRIVER_VERSION "\n");
  •     return 0;
继承事业,薪火相传
