STM32 启动代码 startup.c main函数之前解析(3)
; Vector Table Mapped to Address 0 at Reset                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
__Vectors       DCD     __initial_sp              ; Top of Stack
                DCD     Reset_Handler             ; Reset Handler
                DCD     NMI_Handler               ; NMI Handler
                DCD     HardFault_Handler         ; Hard Fault Handler
                DCD     MemManage_Handler         ; MPU Fault Handler
                DCD     BusFault_Handler          ; Bus Fault Handler
                DCD     UsageFault_Handler        ; Usage Fault Handler
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     0                         ; Reserved
                DCD     SVC_Handler               ; SVCall Handler
                DCD     DebugMon_Handler          ; Debug Monitor Handler
                DCD     0                         ; Reserved
                DCD     OSPendSV            ; PendSV Handler
                DCD     SysTickHandler           ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler           ; Window Watchdog
                DCD     PVD_IRQHandler            ; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler         ; Tamper
                DCD     RTC_IRQHandler            ; RTC
                DCD     FLASH_IRQHandler          ; Flash
                DCD     RCC_IRQHandler            ; RCC
                DCD     EXTI0_IRQHandler          ; EXTI Line 0
                DCD     EXTI1_IRQHandler          ; EXTI Line 1
                DCD     EXTI2_IRQHandler          ; EXTI Line 2
                DCD     EXTI3_IRQHandler          ; EXTI Line 3
                DCD     EXTI4_IRQHandler          ; EXTI Line 4
                DCD     DMAChannel1_IRQHandler    ; DMA Channel 1
                DCD     DMAChannel2_IRQHandler    ; DMA Channel 2
                DCD     DMAChannel3_IRQHandler    ; DMA Channel 3
                DCD     DMAChannel4_IRQHandler    ; DMA Channel 4
                DCD     DMAChannel5_IRQHandler    ; DMA Channel 5
                DCD     DMAChannel6_IRQHandler    ; DMA Channel 6
                DCD     DMAChannel7_IRQHandler    ; DMA Channel 7
                DCD     ADC_IRQHandler            ; ADC
                DCD     USB_HP_CAN_TX_IRQHandler  ; USB High Priority or CAN TX
                DCD     USB_LP_CAN_RX0_IRQHandler ; USB Low  Priority or CAN RX0
                DCD     CAN_RX1_IRQHandler        ; CAN RX1
                DCD     CAN_SCE_IRQHandler        ; CAN SCE
                DCD     EXTI9_5_IRQHandler        ; EXTI Line 9..5
                DCD     TIM1_BRK_IRQHandler       ; TIM1 Break
                DCD     TIM1_UP_IRQHandler        ; TIM1 Update
                DCD     TIM1_TRG_COM_IRQHandler   ; TIM1 Trigger and Commutation
                DCD     TIM1_CC_IRQHandler        ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler           ; TIM2
                DCD     TIM3_IRQHandler           ; TIM3
                DCD     TIM4_IRQHandler           ; TIM4
                DCD     I2C1_EV_IRQHandler        ; I2C1 Event
                DCD     I2C1_ER_IRQHandler        ; I2C1 Error
                DCD     I2C2_EV_IRQHandler        ; I2C2 Event
                DCD     I2C2_ER_IRQHandler        ; I2C2 Error
                DCD     SPI1_IRQHandler           ; SPI1
                DCD     SPI2_IRQHandler           ; SPI2
                DCD     USART1_IRQHandler         ; USART1
                DCD     USART2_IRQHandler         ; USART2
                DCD     USART3_IRQHandler         ; USART3
                DCD     EXTI15_10_IRQHandler      ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler       ; RTC Alarm through EXTI Line
                DCD     USBWakeUp_IRQHandler      ; USB Wakeup from suspend
                AREA    |.text|, CODE, READONLY
继承事业,薪火相传
