STM32文档中关于NVIC寄存器说明的位置(2)
NVIC_Init()这个函数:[url=][/url]
/** * @brief Initializes the NVIC peripheral according to the specified * parameters in the NVIC_InitStruct. * @param NVIC_InitStruct: pointer to a NVIC_InitTypeDef structure that contains * the configuration information for the specified NVIC peripheral. * @retval None */void NVIC_Init(NVIC_InitTypeDef* NVIC_InitStruct){ uint32_t tmppriority = 0x00, tmppre = 0x00, tmpsub = 0x0F; /* Check the parameters */ assert_param(IS_FUNCTIONAL_STATE(NVIC_InitStruct->NVIC_IRQChannelCmd)); assert_param(IS_NVIC_PREEMPTION_PRIORITY(NVIC_InitStruct->NVIC_IRQChannelPreemptionPriority)); assert_param(IS_NVIC_SUB_PRIORITY(NVIC_InitStruct->NVIC_IRQChannelSubPriority)); if (NVIC_InitStruct->NVIC_IRQChannelCmd != DISABLE) { /* Compute the Corresponding IRQ Priority --------------------------------*/ tmppriority = (0x700 - ((SCB->AIRCR) & (uint32_t)0x700))>> 0x08; tmppre = (0x4 - tmppriority); tmpsub = tmpsub >> tmppriority; tmppriority = (uint32_t)NVIC_InitStruct->NVIC_IRQChannelPreemptionPriority << tmppre; tmppriority |= NVIC_InitStruct->NVIC_IRQChannelSubPriority & tmpsub; tmppriority = tmppriority << 0x04; NVIC->IP[NVIC_InitStruct->NVIC_IRQChannel] = tmppriority; /* Enable the Selected IRQ Channels --------------------------------------*/ NVIC->ISER[NVIC_InitStruct->NVIC_IRQChannel >> 0x05] = (uint32_t)0x01 << (NVIC_InitStruct->NVIC_IRQChannel & (uint8_t)0x1F); } else { /* Disable the Selected IRQ Channels -------------------------------------*/ NVIC->ICER[NVIC_InitStruct->NVIC_IRQChannel >> 0x05] = (uint32_t)0x01 << (NVIC_InitStruct->NVIC_IRQChannel & (uint8_t)0x1F); }}
可以看到,它会去设置几个寄存器:NVIC的IP,ISER,ICER等等,NVIC是基址,为:
#define SCS_BASE (0xE000E000) /*!< System Control Space Base Address */#define NVIC_BASE (SCS_BASE + 0x0100) /*!< NVIC Base Address */#define SCB_BASE (SCS_BASE + 0x0D00) /*!< System Control Block Base Address */#define NVIC ((NVIC_Type *) NVIC_BASE) /*!< NVIC configuration struct */
NVIC_Type为:
[url=][/url]
/** @addtogroup CMSIS_CM3_NVIC CMSIS CM3 NVIC memory mapped structure for Nested Vectored Interrupt Controller (NVIC) @{ */typedef struct{ __IO uint32_t ISER[8]; /*!< Offset: 0x000 Interrupt Set Enable Register */ uint32_t RESERVED0[24]; __IO uint32_t ICER[8]; /*!< Offset: 0x080 Interrupt Clear Enable Register */ uint32_t RSERVED1[24]; __IO uint32_t ISPR[8]; /*!< Offset: 0x100 Interrupt Set Pending Register */ uint32_t RESERVED2[24]; __IO uint32_t ICPR[8]; /*!< Offset: 0x180 Interrupt Clear Pending Register */ uint32_t RESERVED3[24]; __IO uint32_t IABR[8]; /*!< Offset: 0x200 Interrupt Active bit Register */ uint32_t RESERVED4[56]; __IO uint8_t IP[240]; /*!< Offset: 0x300 Interrupt Priority Register (8Bit wide) */ uint32_t RESERVED5[644]; __O uint32_t STIR; /*!< Offset: 0xE00 Software Trigger Interrupt Register */} NVIC_Type; /*@}*/ /* end of group CMSIS_CM3_NVIC */ |
