» Xilinx® Spartan®-6 FPGA LX9 MicroBoard支持资源
pengpengpang
(pengpengpang)
来自
中国
156 小时
来自
中国
pengpengpang
发表于 2014-10-23 22:03
资源
Xilinx® Spartan®-6 FPGA LX9 MicroBoardApp Notes/Ref Designs MicroBlaze Software Development with Pre-Built Hardware Platforms >
MicroBlaze Hardware Platforms Overview
Software 101 - Hello World
Software 102 - Test Applications
Software 301 - Micrium uCOS-III Example Application v12.4.01 (PLB)
Software 301 - Micrium uCOS-III Example Application v13.1.01 (AXI)
Creating the AVS6LX9MBHP010 MicroBlaze Hardware Platform (EDK required)
AVS6LX9MBHP010 v12.4.01
AVS6LX9MBHP011 v13.1.01
AVS6LX9MBHP020 v12.4.01
AVS6LX9MBHP030 v12.4.01
AVS6LX9MBHP211 v13.1.01
AVS6LX9MBHP212 v13.1.01
AVS6LX9MBHP220 v13.1.01
XPS Source: AVS6LX9MBHP010 v12.4.01 (EDK Required)
XPS Source: AVS6LX9MBHP011 v13.1.01 (EDK Required)
XPS Source: AVS6LX9MBHP020 v12.4.01 (EDK Required)
XPS Source: AVS6LX9MBHP030 v12.4.01 (EDK Required)
XPS Source: AVS6LX9MBHP211 v13.1.01 (EDK Required)
XPS Source: AVS6LX9MBHP212 v13.1.01 (EDK Required)
XPS Source: AVS6LX9MBHP220 v13.1.01 (EDK Required)
EDK 13.1 Tutorials (EDK Required) >
EDK01 - Creating Embedded System
EDK02 - Adding EDK IP
EDK03 - Adding Custom EDK IP
EDK04 - Embedded Simulation with ISim
EDK05 - Embedded Debugging with ChipScope Pro
EDK - Creating a MicroBlaze SPI Flash Bootloader (Zip)
Solution: EDK01 (Zip)
Solution: EDK02 (Zip)
Solution: EDK03 (Zip)
Solution: EDK04 (Zip)
Solution: EDK05 (Zip)
Solution: SPI Flash Bootloader (Zip)
EDK 12.4 Tutorials (EDK Required) >
EDK03 - Adding Custom IP
EDK04 - ISE Integration
EDK05 - Embedded Simulation
EDK06 - Software Debugging SDK
Solution: EDK06 (Zip)
ISE Design Suite 13.1 >
PicoBlaze for the Xilinx Spartan-6 LX9 MicroBoard (VHDL)
ISE Design Suite 12.4 >
Blinking LED Design using Command-line Tools (Verilog and VHDL)
Implementing XAPP1141 with the Spartan-6 LX9 MicroBoard
PicoBlaze for the Xilinx Spartan-6 LX9 MicroBoard (VHDL) - updated: 4/19/11
MIG Traffic Generator Design (Verilog and VHDL)
BOM >
Xilinx Spartan-6 LX9 MicroBoard, Rev. B - BOM
Other >
White Paper: High-Volume Spartan-6 FPGAs: Performance and Power Leadership by Design
Master User Constraints File
Design Kit Discussion Group >
Schematics >
Xilinx Spartan-6 LX9 MicroBoard, Rev. B1 - Schematics
Xilinx Spartan-6 LX9 MicroBoard, Rev. B - Schematics
Xilinx Spartan-6 LX9 MicroBoard, Rev. B - Artwork Prints
Test Files >
Factory Test Flash Image and Programming Instructions
User Guide >
Xilinx Spartan-6 LX9 MicroBoard - Hardware User Guide
Silicon Labs CP201x USB-to-UART Setup Guide v.1.0
Spartan-6 LX9 MicroBoard Configuration Guide v.1.3 (4/18/11)
Xilinx Spartan-6 LX9 MicroBoard - Quick Start Card
Xilinx Spartan-6 LX9 MicroBoard - Getting Started Guide
XBD >
XBD2 (IP-XACT) Files (EDK 13.1) - AXI
XBD Files (EDK 12.4/13.1) - PLB
XBD Files (EDK 13.2)
LX9
Spartan-6
