FlashObj::FlashObj(void) { McBSP1Init(); FlashInit(); } void FlashObj::::McBSP1Init(void)//SPI配置 { McBSP1->SPSA = SPCR1; McBSP1->SPSD = (0x01 << SPCR1_RJUST);//接收符号扩展及判别模式13~14 McBSP1->SPSA = SPCR2; McBSP1->SPSD = (1 << SPCR2_FRST) //帧同步发生器复位 | (1 << SPCR2_GRST) //采样率发生器复位 | (1 << SPCR2_XEMPTY)//发送移位寄存器空 | (1 << SPCR2_XRDY); //发送准备好 McBSP1->SPSA = PCR; McBSP1->SPSD = (1 << PCR_XIOEN) //发送通用I/O模式位 | (1 << PCR_RIOEN) //接收通用I/O模式位 | (1 << PCR_FSXM) //发送帧同步模式位(FLASH的片选信号) | (1 << PCR_CLKXM) //发送器时钟模式位 | (1 << PCR_FSXP); //关闭FLASH的片选信号(FSX="1") } void FlashObj::FlashInit(void) { FlashDisable(); for(int i = 0; i < 256; i ) { FlashBuffers = 0; } MakerId = 0; DeviceId = 0; ThirdCyc = 0; FourthCyc = 0; }
void FlashObj::FlashEnable(void) { McBSP1->SPSA = PCR; McBSP1->SPSD &= ~(1 << PCR_FSXP);//打开FLASH的片选信号(FSX="0") } void FlashObj::FlashDisable(void) { McBSP1->SPSA = PCR; McBSP1->SPSD |= (1 << PCR_FSXP);//关闭FLASH的片选信号(FSX="1") } void FlashObj::FlashWait(void) { McBSP1->SPSA = PCR; do { __nop(); __nop(); } while((McBSP1->SPSD & (1 << PCR_FSRP)) == 0);//读FSR信号 } void FlashObj::FlashSck(void) { // McBSP1->SPSA = PCR; // __nop(); // __nop(); McBSP1->SPSD |= (1 << PCR_FSXP);//FSX="1" __nop(); // __nop(); McBSP1->SPSD &= ~(1 << PCR_FSXP);//FSX="0" __nop(); // __nop(); } /*----------------------------------------- K9F1G08--128M*8bit -----------------------------------------*/ bool FlashObj::FlashId(void) { bool flag; FlashEnable();//使能FLASH Port_Cle = 0x90; __nop();//此处绝对不能少于2个nop() __nop(); __nop(); __nop(); __nop(); __nop(); Port_Cle = 0x00; // __nop();//此处绝容不下1个nop() MakerId = Port_Data; FlashSck();//发送时钟信号 DeviceId = Port_Data; FlashSck();//发送时钟信号 ThirdCyc = Port_Data; FlashSck();//发送时钟信号 FourthCyc = Port_Data; FlashDisable();//禁止FLASH flag = (MakerId == 0xec) && (DeviceId == 0xf1) && (ThirdCyc == 0x80) && (FourthCyc == 0x15); return flag;//K9F1G08的ID={0xec,0xec,0xf1,0x80,0x15} } /*--------------------------------------------- 块擦除 ---------------------------------------------*/ bool FlashObj::BlockErase(unsigned int Sector) { bool flag = false; FlashEnable();//使能FLASH Port_Cle = 0x60; __nop(); __nop(); Port_Ale = Sector & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 8) & 0xff; __nop(); __nop(); Port_Cle = 0xd0; FlashWait(); Port_Cle = 0x70; flag = (Port_Data & 0x01) == 0; FlashDisable();//禁止FLASH return flag; } void FlashObj:ageRead(unsigned long Sector, unsigned int Length, unsigned int * DataBuff) { FlashEnable();//使能FLASH Port_Cle = 0; __nop(); __nop(); Port_Ale = Sector & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 8) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 16) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 24) & 0xff; __nop(); __nop(); Port_Cle = 0x30; FlashWait(); McBSP1->SPSA = PCR; for(int i = 0; i < Length; i ) { FlashSck();//发送时钟信号 DataBuff = Port_Data; } FlashDisable();//禁止FLASH } bool FlashObj:ageWrite(unsigned long Sector, unsigned int Length, unsigned int * DataBuff) { bool flag; FlashEnable();//使能FLASH Port_Cle = 0x80; __nop(); __nop(); Port_Ale = Sector & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 8) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 16) & 0xff; __nop(); __nop(); Port_Ale = (Sector > FlashObj::FlashObj(void) { McBSP1Init(); FlashInit(); } void FlashObj::::McBSP1Init(void)//SPI配置 { McBSP1->SPSA = SPCR1; McBSP1->SPSD = (0x01 << SPCR1_RJUST);//接收符号扩展及判别模式13~14 McBSP1->SPSA = SPCR2; McBSP1->SPSD = (1 << SPCR2_FRST) //帧同步发生器复位 | (1 << SPCR2_GRST) //采样率发生器复位 | (1 << SPCR2_XEMPTY)//发送移位寄存器空 | (1 << SPCR2_XRDY); //发送准备好 McBSP1->SPSA = PCR; McBSP1->SPSD = (1 << PCR_XIOEN) //发送通用I/O模式位 | (1 << PCR_RIOEN) //接收通用I/O模式位 | (1 << PCR_FSXM) //发送帧同步模式位(FLASH的片选信号) | (1 << PCR_CLKXM) //发送器时钟模式位 | (1 << PCR_FSXP); //关闭FLASH的片选信号(FSX="1") } void FlashObj::FlashInit(void) { FlashDisable(); for(int i = 0; i < 256; i ) { FlashBuffers = 0; } MakerId = 0; DeviceId = 0; ThirdCyc = 0; FourthCyc = 0; }
void FlashObj::FlashEnable(void) { McBSP1->SPSA = PCR; McBSP1->SPSD &= ~(1 << PCR_FSXP);//打开FLASH的片选信号(FSX="0") } void FlashObj::FlashDisable(void) { McBSP1->SPSA = PCR; McBSP1->SPSD |= (1 << PCR_FSXP);//关闭FLASH的片选信号(FSX="1") } void FlashObj::FlashWait(void) { McBSP1->SPSA = PCR; do { __nop(); __nop(); } while((McBSP1->SPSD & (1 << PCR_FSRP)) == 0);//读FSR信号 } void FlashObj::FlashSck(void) { // McBSP1->SPSA = PCR; // __nop(); // __nop(); McBSP1->SPSD |= (1 << PCR_FSXP);//FSX="1" __nop(); // __nop(); McBSP1->SPSD &= ~(1 << PCR_FSXP);//FSX="0" __nop(); // __nop(); } /*----------------------------------------- K9F1G08--128M*8bit -----------------------------------------*/ bool FlashObj::FlashId(void) { bool flag; FlashEnable();//使能FLASH Port_Cle = 0x90; __nop();//此处绝对不能少于2个nop() __nop(); __nop(); __nop(); __nop(); __nop(); Port_Cle = 0x00; // __nop();//此处绝容不下1个nop() MakerId = Port_Data; FlashSck();//发送时钟信号 DeviceId = Port_Data; FlashSck();//发送时钟信号 ThirdCyc = Port_Data; FlashSck();//发送时钟信号 FourthCyc = Port_Data; FlashDisable();//禁止FLASH flag = (MakerId == 0xec) && (DeviceId == 0xf1) && (ThirdCyc == 0x80) && (FourthCyc == 0x15); return flag;//K9F1G08的ID={0xec,0xec,0xf1,0x80,0x15} } /*--------------------------------------------- 块擦除 ---------------------------------------------*/ bool FlashObj::BlockErase(unsigned int Sector) { bool flag = false; FlashEnable();//使能FLASH Port_Cle = 0x60; __nop(); __nop(); Port_Ale = Sector & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 8) & 0xff; __nop(); __nop(); Port_Cle = 0xd0; FlashWait(); Port_Cle = 0x70; flag = (Port_Data & 0x01) == 0; FlashDisable();//禁止FLASH return flag; } void FlashObj:ageRead(unsigned long Sector, unsigned int Length, unsigned int * DataBuff) { FlashEnable();//使能FLASH Port_Cle = 0; __nop(); __nop(); Port_Ale = Sector & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 8) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 16) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 24) & 0xff; __nop(); __nop(); Port_Cle = 0x30; FlashWait(); McBSP1->SPSA = PCR; for(int i = 0; i < Length; i ) { FlashSck();//发送时钟信号 DataBuff = Port_Data; } FlashDisable();//禁止FLASH } bool FlashObj:ageWrite(unsigned long Sector, unsigned int Length, unsigned int * DataBuff) { bool flag; FlashEnable();//使能FLASH Port_Cle = 0x80; __nop(); __nop(); Port_Ale = Sector & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 8) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 16) & 0xff; __nop(); __nop(); Port_Ale = (Sector >> 24) & 0xff; __nop(); __nop(); McBSP1->SPSA = PCR; for(int i = 0; i < Length; i ) { Port_Data = DataBuff & 0xff; __nop(); __nop(); } Port_Cle = 0x10; FlashWait(); Port_Cle = 0x70; flag = (Port_Data & 0x01) == 0; FlashDisable();//禁止FLASH return flag; }
