pic32 spi驱动pmodcls lcd液晶屏(2)
5除此之外,系统时钟设置需要注意。
参考武林大侠那副比较经典点的图示:
/*  configure bit setting. Fcy = 72MHZ,Fpb = 9MHZ */
#pragma  config POSCMOD = XT, FNOSC = PRIPLL
#pragma  config FPLLMUL = MUL_18, FPLLIDIV = DIV_2, FPLLODIV = DIV_1
#pragma  config FPBDIV = DIV_8, FWDTEN = OFF, CP = OFF, BWP = OFF
即使用的时钟计算方式为:系统频率Fcy = ( ( 8Mhz / 2 ) * 18 ) / 1
72MHZ;
外围设备总线时钟Fpb = 72 / FPBDIV
= 9 MHZ;
6、源码
* xiaoyang@HIT 2011.1.15
* cool@HIT 2010.1.21 complete
#include
#include  "spi.h"
#include  "types.h"
#include
/* SPI Control &  Baud Rate Configuration */
#define  SPI_CONF        0x8060                                //  SPI_ON | SPI_MSTEN
#define  SPI_BRG                3                                        //  9MHZ /8 =
/* SPI Slave Pin  Config */
#define SPI_SS
                0x200
                        //  RD9 for SS port
#define  ACTIVATE()
        PORTDCLR=SPI_SS                        //  tris control for CS pin
#define  DEACTIVATE()        PORTDSET=SPI_SS
*        led_init
void led_init()
TRISB  =  0;                                //  LED1-4 output
AD1PCFG =  0xffff;                //  all PORTB as digital
PORTB = 0x0;
*        spi_init
void spi_init()
int  rData;
/*  Setup SS Pin */
TRISDCLR  =  SPI_SS;                        //
DEACTIVATE();
/*  Configurate Master */
SPI1CONCLR  =  SPI_ON;                //  Stop and Reset
rData  =  SPI1BUF;                                        //  Clr the receive buffer
SPI1BRG  =  SPI_BRG;                        //  Set SCLK = Fp/32
SPI1CON  =  SPI_CONF;                        //          Reconfigurated and Ready to  Work
* spi using the same interface for receive  and transport
u8 spi1_8TxRx(u8 ch)
while(SPI1STATbits.SPIBUSY);                        //  Check
SPI1BUF  = ch;
while(!SPI1STATbits.SPIRBF);                        //waiting  for transfer complete
return  SPI1BUF;
void  PmodCLS_DisplyString(char* str)
u8  len=0,ch;
ACTIVATE();
spi1_8TxRx(0x1B);                          //  ESC character
spi1_8TxRx(0x5B);                          //  [ character
spi1_8TxRx(0x30);                          //  zero
spi1_8TxRx(0x6A);                          //  j- command for clear display and home cursor
while(*str)  {
spi1_8TxRx(*str++);
len++;
DEACTIVATE();
return;
void  PmodCLS_sendCmd(char* cmd)
ACTIVATE();
spi1_8TxRx(0x1B);
while(*cmd)  {
spi1_8TxRx(*cmd++);
DEACTIVATE();
继承事业,薪火相传
