SD_STM32_SPI驱动+FatFs文件系统(4)
三、FatFs移植示例。
支持格式化文件系统、读写、目录等。目前下面的代码只支持一个设备,如若想支持多个设备的文件系统,比如在SD卡、SPI FLASH中均实现文件系统,改动下面代码即可:
对每个Physical drive nmuber响应;底层的驱动只需要提供初始化(包括获取设备的容量)、读写即可。如果希望实现NFS、串口硬盘等,只需要把这几个接口通过通信链路(网络、串口等)映射过去。
[cpp] view plaincopy
- /* Low level disk I/O module skeleton for FatFs (C)ChaN, 2007 */
- /* This is a stub disk I/O module that acts as front end of the existing */
- /* disk I/O modules and attach it to FatFs module with common interface. */
- #include "diskio.h"
- #include "stm32f10x.h"
- #include "SD_drive.h"
- /* Correspondence between physical drive number and physical drive. */
- #define ATA 0
- #define MMC 1
- #define USB 2
- static
int bus_in_sdio;
- * @brief 检查sd卡是否就绪
- * @return 0:检测成功
- * -1:检测失败
- static
int check_sdcard(void) - {
- return check_maincard();
- /* Inidialize a Drive */
- DSTATUS disk_initialize (
- BYTE drv /* Physical drive nmuber (0..) */
- if( check_sdcard() == 0 )
- bus_in_sdio = 1;
- return RES_OK;
- return RES_ERROR;
- DSTATUS disk_unmount(BYTE drv)
- bus_in_sdio = 0;
- return RES_OK;
- DWORD get_fattime ()
- return 0;
- /* Return Disk Status */
- DSTATUS disk_status (
- if(bus_in_sdio == 0)
- return disk_initialize(drv);
- //SD_GetStatus(); // == 0 )
- //return RES_ERROR;
- return RES_OK;
- /* Read Sector(s) */
- DRESULT disk_read (
- BYTE drv, /* Physical drive nmuber (0..) */
- BYTE *buff, /* Data buffer to store read data */
- DWORD sector, /* Sector address (LBA) */
- BYTE count /* Number of sectors to read (1..255) */
- DRESULT res;
- res = (DRESULT)(read_card(sector, count, buff));
- if( res != 0 )
- return RES_ERROR;
- else
- return RES_OK;
- /* Write Sector(s) */
- #if _READONLY == 0
- DRESULT disk_write (
- const
BYTE *buff, /* Data to be written */
- BYTE count /* Number of sectors to write (1..255) */
- DRESULT res;
- res = (DRESULT)(write_card(sector, count, (unsigned char*)buff));
- if( res == 0)
- return RES_OK;
- else
- return RES_ERROR;
- #endif /* _READONLY */
- /* Miscellaneous Functions */
- // 返回磁盘状态
- DRESULT disk_ioctl (
- BYTE ctrl, /* Control code */
- void *buff /* Buffer to send/receive control data */
- DRESULT res;
- if (drv)
- return RES_PARERR; //仅支持单磁盘操作,否则返回参数错误
- //FATFS目前版本仅需处理CTRL_SYNC,GET_SECTOR_COUNT,GET_BLOCK_SIZ三个命令
- switch(ctrl)
- case CTRL_SYNC:
- res = RES_OK;
- break;
- case GET_BLOCK_SIZE:
- *(WORD*)buff = 1;
- res = RES_OK;
- break;
- case GET_SECTOR_COUNT: //读卡容量
- *(DWORD*)buff = sd_state.capacity;
- break;
- default:
- res = RES_PARERR;
- break;
- return res;
