你们用 sysgen 生成 netlist 的时候有没有出现过如下问题啊?: Begin generation Checking model status Checking simulation times Performing compilation and generation
*** ERROR ***
Errors occurred during netlist generation. Error using ==> sim Error reported by S-function 'sysgen' in 'adder_saturate/Gateway In':
Summary of errors from all sources:
(NOTE: None of the errors were associated with a particular block; the block reporting this summary was chosen at random.)
-------------------------------------------------------------------------- Summary of Errors: Error 0001: caught standard exception Block: Unspecified --------------------------------------------------------------------------
Error 0001:
Reported by: Unspecified
Details: standard exception: XNetlistEngine: An exception was raised: com.xilinx.sysgen.netlist.NetlistInternal: couldn't make clock wrapper at D:/MATLAB/R2006a/toolbox/xilinx/sysgen/scripts/SgPass2Netlist.pm line 107.
--------------------------------------------------------------------------. 哪位仁兄解决了啊???
