Embest Atmel AT91SAM3U ARM-CM3 MCU开发方案(5)
技术数据:
Parameter         Description
Supply Voltage    5 Volts DC (provided by power adapter)
Supply Current    210mA typical, 320mA maximum
XTAL Frequency    12 MHz
Microcontroller   AT91SAM3U4E LQFP 144 Pins
Peripherals       2 × RS232 Interface,
               1 × USB Device Interface (High-speed),
               1 × 2.8” Color graphic display (240x320),
               1 × MicroSD Memory Card connector,
               1 × JTAG Interface,
               5 × Push Buttons (Reset, Wake Up, Tampering, User),
               2 × BNC Interface,
               1 x RTC Unit with Battery,
               1 × Analog Input (connected to potentiometer),
               1 × Analog Output (connected to speaker by default)
Board Size     135mm x 90mm (5.3" x 3.5")
Weight         320g
图4.ATSAM3U 开发板方框图
图5.ATSAM3U 开发板电路图(1)
图6.ATSAM3U 开发板电路图(2)
图7.ATSAM3U 开发板电路图(3)
继承事业,薪火相传
