在Spartan-3系列FPGA中使用LUT构建分布式RAM(4)---‘连载――我与FPGA活动’”
   前面讲了分布式RAM的方方面面,下面以RAM_16S为例,分别给出其在VHDL和Verilog HDL下面的模板代码(在ISE Project Navigator中选择 Edit--- Language Templates,然后选择VHDL 或者Verilog, 最后是Synthesis Templates --- RAM,在http://xilinx.eetrend.com/blog/776中也有具体调用过程的描述)。CORE Generator可以产生类似的代码以供行为仿真使用,它们可以在ISE Project Navigator中双击.coe文件看到。
VHDL Template Example
-- Module: RAM_16S
-- Description: VHDL instantiation template
-- Distributed RAM
-- Single Port 16 x 1
-- Can also be used for RAM16X1S_1
-- Device: Spartan-3 Family
-- Components Declarations:
component RAM16X1S
-- pragma translate_off
generic (
-- RAM initialization (“0” by default) for functional simulation:
INIT : bit_vector := X"0000"
-- pragma translate_on
port (
D : in std_logic;
WE : in std_logic;
WCLK : in std_logic;
A0 : in std_logic;
A1 : in std_logic;
A2 : in std_logic;
A3 : in std_logic;
O : out std_logic
end component;
-- Architecture section:
-- Attributes for RAM initialization ("0" by default):
attribute INIT: string;
attribute INIT of U_RAM16X1S: label is "0000";
-- Distributed RAM Instantiation
U_RAM16X1S: RAM16X1S
port map (
D => , -- insert Data input signal
WE => , -- insert Write Enable signal
WCLK => , -- insert Write Clock signal
A0 => , -- insert Address 0 signal
A1 => , -- insert Address 1 signal
A2 => , -- insert Address 2 signal
A3 => , -- insert Address 3 signal
O => -- insert Data output signal
R
Verilog Template Example
// Module: RAM_16S
// Description: Verilog instantiation template
// Distributed RAM
// Single Port 16 x 1
// Can also be used for RAM16X1S_1
// Device: Spartan-3 Family
// Syntax for Synopsys FPGA Express
// synopsys translate_off
defparam
//RAM initialization (“0” by default) for functional simulation:
U_RAM16X1S.INIT = 16'h0000;
// synopsys translate_on
//Distributed RAM Instantiation
RAM16X1S U_RAM16X1S (
.D(), // insert input signal
.WE(), // insert Write Enable signal
.WCLK(), // insert Write Clock signal
.A0(), // insert Address 0 signal
.A1(), // insert Address 1 signal
.A2(), // insert Address 2 signal
.A3(), // insert Address 3 signal
.O() // insert output signal
// synthesis attribute declarations
/* synopsys attribute
INIT "0000"
          CORE Generator产生分布式RAM、同步FIFO和异步FIFO的说明文档可以分别在如下网址找到。
• CORE Generator: 分布式RAM模块
http://www.xilinx.com/ipcenter/catalog/logicore/docs/dist_mem.pdf
• CORE Generator: 同步FIFO模块
http://www.xilinx.com/ipcenter/catalog/logicore/docs/sync_fifo.pdf
• CORE Generator: 异步FIFO模块
http://www.xilinx.com/ipcenter/catalog/logicore/docs/async_fifo.pdf
