STM32之CAN---发送管理分析(4)
7 与CAN发送有关的固件发送接口发送接口如下:
[cpp] view plaincopy
  •   * @brief  Initiates and transmits a CAN frame message.
  •   * @param  CANx: where x can be 1 or 2 to to select the CAN peripheral.
  •   * @param  TxMessage: pointer to a structure which contains CAN Id, CAN DLC and CAN data.
  •   * @retval The number of the mailbox that is used for transmission or
  •   *         CAN_TxStatus_NoMailBox if there is no empty mailbox.
  • uint8_t CAN_Transmit(CAN_TypeDef* CANx, CanTxMsg* TxMessage);
获取发送状态接口如下:[cpp] view plaincopy
  •   * @brief  Checks the transmission status of a CAN Frame.
  •   * @param  CANx: where x can be 1 or 2 to select the CAN peripheral.
  •   * @param  TransmitMailbox: the number of the mailbox that is used for transmission.
  •   * @retval CAN_TxStatus_Ok if the CAN driver transmits the message,
  •   *         CAN_TxStatus_Failed in an other case.
  • uint8_t CAN_TransmitStatus(CAN_TypeDef* CANx, uint8_t TransmitMailbox);
8 一个示例[cpp] view plaincopy
  • CanTxMsg TxMessage;
  • int i;
  • if(id_fmt == STD_ID)//如果是标准CAN ID
  •     TxMessage.StdId = send_frame->id;  //设置标准CAN ID
  •     TxMessage.IDE = CAN_ID_STD;   //设置IDE为标准CAN ID
  • else
  •     TxMessage.StdId = (send_frame->
  •     id >>18) & 0x7FF; //设置扩展CAN ID的标准基本ID部分
  •     TxMessage.ExtId = send_frame->id & 0x3FFFF;     //设置扩展CAN ID的扩展ID部分
  •     TxMessage.IDE = CAN_ID_EXT;   //设置IDE为扩展CAN ID
  • TxMessage.RTR = CAN_RTR_DATA; //数据帧
  • TxMessage.DLC = 8;  //数据长度
  • for(i=0;i<8;i++)<br>
  •     TxMessage.Data = send_frame->data_buff;
  • CAN_Transmit(CAN1,&TxMessage);
继承事业,薪火相传
哎哟 这个貌似看起来还可以哦。。你们看看
