单片机的流水灯程序
单片机的流水灯程序
#Include"EM78x153xx.H"
#Define DISI()  _asm{Disi}
#Define ENI()  _asm{Eni}
#Define SLEP()  _asm{Slep}
#Define NOP()  _asm{Nop}
#Define WDTC() _asm{Wdtc}
Typedef Unsigned Char Uchar;
Typedef Unsigned Int Uint;
Typedef Unsigned Short Ushort;
#Define Ledl PORT5
#Define Ledh PORT6
Void Delay(Void)
{Uchar I,J;
For(J=0;J<200;J++)
For(I=0;I<200;I++)NOP();
Const Ushort Rundata[16]={0xfffe,0xfffc,0xfff8,0xfff0,
      0xffe0,0xffc0,0xff80,0xff00,
      0xfe00,0xfc00,0xf800,0xf000,
      0xe000,0xc000,0x8000,0x0000};
Void Main(Void)
{Uchar I,J,K;
Uint Run;
WDTC();//清看门狗
DISI();//禁止中断
STATUS=0X00;//清除状态标志位
P5CR=0x00;//置P5为输出口
P6CR=0x00;//置P6为输出口
PDCR=0x00;//禁止P5,P6下拉
ODCR=0x00;//禁止P6开漏
PHCR=0x00;//禁止P6上拉
For(;;)
For(I=0,K=0;I<16;I++,K--)
  {Run=Rundata[I];
  For(J=0;J<K;J++)
    {Ledl=Run;
    Ledh=(Run>>8);
    Delay();
Void _intcall Interrupt(Void) @ Int
  // Write Your Code (Inline Assembly Or C) Here
  //Restore ACC,R3,R4
  _asm
      Reti            //Tell Compiler To Recover Common Registers Here
      SWAP 0X1F    ;Restore A
      SWAPA 0X1F
Void _intcall Interrupt_l(Void) @ 0x08ow_int 0
   _asm
      //Save A --> 0x1F
      MOV 0X1F,A   ;Backup A To 0x1F
