收音机模块TEA5767的C语言控制程序
   TEA5767采用I2C或者三线接口控制,我是用的I2C,单片机用STC89C52,带1K EEPROM,可以掉电存台,1602LCD显示.
  TEA5767读写数据都是5个字节,其中PLL参数14位,具体数据格式请看Datasheet.以下程序中的函数可以直接在主程序中调用.
  #Include "Iic.C"
  #Define Max_freq 108000
  #Define Min_freq 87500
  Unsigned Char Radio_write_data[5]={0x29,0xc2,0x20,0x11,0x00}; //要写入TEA5767的数据
  Unsigned Char Radio_read_data[5]; //TEA5767读出的状态
  Unsigned Int Default_pll=0x29c2;//0x29f9; //默认存台的Pll,87.8MHz
  //Unsigned Int Max_pll=0x339b; //108MHz时的Pll,
  //Unsigned Int Min_pll=9000; //70MHz时的Pll
  Void Radio_write(Void)
  Unsigned Char I;
  Iic_start();
  Iic_write8bit(0xc0); //TEA5767写地址
  If(!Iic_testack())
  For(I=0;I<5;I++)
  Iic_write8bit(Radio_write_data[I]);
  Iic_ack();
  Iic_stop();
  //读TEA5767状态,并转换成频率
  Void Radio_read(Void)
  Unsigned Char I;
  Unsigned Char Temp_l,Temp_h;
  Pll=0;
  Iic_start();
  Iic_write8bit(0xc1); //TEA5767读地址
  If(!Iic_testack())
  For(I=0;I<5;I++)
  Radio_read_data[I]=Iic_read8bit();
  Iic_ack();
  Iic_stop();
  Temp_l=Radio_read_data[1];
  Temp_h=Radio_read_data[0];
  Temp_h&=0x3f;
  Pll=Temp_h*256+Temp_l;
  Get_frequency();
  //由频率计算PLL
  Void Get_pll(Void)
  Unsigned Char Hlsi;
  Unsigned Int Twpll=0;
  Hlsi=Radio_write_data[2]&0x10;
  If (Hlsi)
  Pll=(Unsigned Int)((Float)((Frequency+225)*4)/(Float)32.768); //频率单位:K
  Else
  Pll=(Unsigned Int)((Float)((Frequency-225)*4)/(Float)32.768); //频率单位:K
  //由PLL计算频率
  Void Get_frequency(Void)
  Unsigned Char Hlsi;
  Unsigned Int Npll=0;
  Npll=Pll;
  If (Hlsi)
  Frequency=(Unsigned Long)((Float)(Npll)*(Float)8.192-225); //频率单位:KHz
  Else
  Frequency=(Unsigned Long)((Float)(Npll)*(Float)8.192+225); //频率单位:KHz
  //手动设置频率,Mode=1,+0.1MHz; Mode=0:-0.1MHz ,不用考虑TEA5767用于搜台的相关位:SM,SUD
  Void Search(Bit Mode)
  Radio_read();
  If(Mode)
  Frequency+=100;
  If(Frequency>Max_freq)
  Frequency=Min_freq;
  Else
  Frequency-=100;
  If(Frequency
  Frequency=Max_freq;
  Get_pll();
  Radio_write_data[0]=Pll/256;
  Radio_write_data[1]=Pll%256;
  Radio_write_data[2]=0x20;
  Radio_write_data[3]=0x11;
  Radio_write_data[4]=0x00;
  Radio_write();
  //自动搜台,Mode=1,频率增加搜台; Mode=0:频率减小搜台,不过这个好像不能循环搜台
  Void Auto_search(Bit Mode)
  Radio_read();
  Get_pll();
  If(Mode)
  Radio_write_data[2]=0xa0;
  Else
  Radio_write_data[0]=Pll/256+0x40;
  Radio_write();
  Radio_read();
  While(!(Radio_read_data[0]&0x80)) //搜台成功标志
  Radio_read();
  Disp_freq(9,1);
