做了个上位机
define ADC1_DR_Address ((u32)0x4001244C)
vu16 AD_Value[2];
关键代码
void ADC1_Configuration(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //连续转换开启
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 2; //设置转换序列长度为2
ADC_Init(ADC1, &ADC_InitStructure);
//ADC内置温度传感器使能(要使用片内温度传感器,切忌要开启它)
ADC_TempSensorVrefintCmd(ENABLE);
//常规转换序列1:通道10
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_13Cycles5);
//常规转换序列2:通道16(内部温度传感器),采样时间>2.2us,(239cycles)
ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 2, ADC_SampleTime_239Cycles5);
// Enable ADC1
ADC_Cmd(ADC1, ENABLE);
// 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
ADC_DMACmd(ADC1, ENABLE);
// 下面是ADC自动校准,开机后需执行一次,保证精度
// Enable ADC1 reset calibaration register
ADC_ResetCalibration(ADC1);
// Check the end of ADC1 reset calibration register
while(ADC_GetResetCalibrationStatus(ADC1));
// Start ADC1 calibaration
ADC_StartCalibration(ADC1);
// Check the end of ADC1 calibration
while(ADC_GetCalibrationStatus(ADC1));
// ADC自动校准结束---------------
* Function Name : DMA_Configuration
* Description : DMA设置:从ADC模块自动读转换结果至内存
* Input : None
* Output : None
* Return : None
void DMA_Configuration(void)
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
//BufferSize=2,因为ADC转换序列有2个通道
//如此设置,使序列1结果放在AD_Value[0],序列2结果放在AD_Value[1]
DMA_InitStructure.DMA_BufferSize = 2;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
//循环模式开启,Buffer写满后,自动回到初始地址开始传输
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
//配置完成后,启动DMA通道
DMA_Cmd(DMA1_Channel1, ENABLE);
