Android arm Linux Kernel启动流程(5)
然后就是重定位了,即都加上一个偏移,经过重定位以后就都是绝对地址了。
not_relocated: mov r0, #0
1: str r0, [r2], #4 @ clear bss
str r0, [r2], #4
str r0, [r2], #4
str r0, [r2], #4
cmp r2, r3
blo 1b
* The C runtime environment should now be setup
* sufficiently. Turn the cache on, set up some
* pointers, and start decompressing.
bl cache_on
重定位完成以后打开cache,具体这个打开cache的过程咱没仔细研究过,大致过程是先从C0里面读到processor ID,然后根据ID来进行cache_on。
解压的过程首先是在堆栈之上申请一个空间
* Check to see if we will overwrite ourselves.
* r4 = final kernel address
* r5 = start of this image
* r2 = end of malloc space (and therefore this image)
* We basically want:
* r4 >= r2 -> OK
* r4 + image length <= r5 -> OK
cmp r4, r2
bhs wont_overwrite
sub r3, sp, r5 @ > compressed kernel size
add r0, r4, r3, lsl #2 @ allow for 4x expansion
cmp r0, r5
bls wont_overwrite
mov r5, r2 @ decompress after malloc space
mov r0, r5
mov r3, r7
bl decompress_kernel
add r0, r0, #127 + 128 @ alignment + stack
bic r0, r0, #127 @ align the kernel length |
