5. 进休眠前的最后汇编段程序(arch/arm/mach-s3c2410/sleep.s)
ENTRY(s3c2410_cpu_suspend)
stmfd sp!, { r4 - r12, lr }
@@ store co-processor registers
mrc p15, 0, r4, c15, c1, 0 @ CP access register
mrc p15, 0, r5, c13, c0, 0 @ PID
mrc p15, 0, r6, c3, c0, 0 @ Domain ID
mrc p15, 0, r7, c2, c0, 0 @ translation table base address
mrc p15, 0, r8, c1, c0, 0 @ control register
stmia r0, { r4 - r13 }
@@ flush the caches to ensure everything is back out to
@@ SDRAM before the core powers down
#ifndef CONFIG_CPU_DCACHE_WRITETHROUGH
bl arm920_flush_kern_cache_all
#endif
@@ prepare cpu to sleep
ldr r4, =S3C2410_REFRESH
ldr r5, =S3C24XX_MISCCR
ldr r6, =S3C2410_CLKCON
ldr r7, [ r4 ] @ get REFRESH (and ensure in TLB)
ldr r8, [ r5 ] @ get MISCCR (and ensure in TLB)
ldr r9, [ r6 ] @ get CLKCON (and ensure in TLB)
orr r7, r7, #S3C2410_REFRESH_SELF @ SDRAM sleep command
orr r8, r8, #(S3C2410_MISCCR_USBSUSPND0 | S3C2410_MISCCR_USBSUSPND1) @suspend usb
orr r8, r8, #(S3C2400_MISCCR_SPUCR_LDIS | S3C2400_MISCCR_SPUCR_HDIS) @suspend d(0-31)
orr r8, r8, #S3C2410_MISCCR_SDSLEEP @ SDRAM power-down signals
orr r9, r9, #S3C2410_CLKCON_POWER @ power down command
teq pc, #0 @ first as a trial-run to load cache
bl s3c2410_do_sleep
teq r0, r0 @ now do it for real
b s3c2410_do_sleep @
@@ align next bit of code to cache line
.align 8
s3c2410_do_sleep:
streq r7, [ r4 ] @ SDRAM sleep command
mov r0, #0x1000
1: subs r0, r0, #1 @wait until the SelfRefresh is released
bne 1b
streq r8, [ r5 ] @ SDRAM power-down config
streq r9, [ r6 ] @ CPU sleep
1: beq 1b
mov pc, r14
2、唤醒部分
1、Uboot部分(u-boot-1.1.4/cpu/arm920t/start.s)
reset:
#if 0
mrs r0, cpsr /* Set the cpu to SVC32 mode */
bic r0, r0, #0x1f
orr r0, r0, #0xd3
msr cpsr, r0
#endif
/* disable watchdog timer */
mov r0, #WTCON_BASE
ldr r1, =0x0
str r1, [r0, #oWTCON]
* mask all IRQs by setting all bits in the INTMR - default
mov r0, #INT_BASE
ldr r1, =0xffffffff
str r1, [r0, #oINTMSK]
ldr r1, =0x7ff
str r1, [r0, #oINTSUBMSK]
mov r0, #CLK_BASE
ldr r1, =0xffffffff
str r1, [r0, #oLOCKTIME]
/* FCLK:HCLK CLK */
ldr r1, =0x0
str r1, [r0, #oCAMDIVN]
ldr r1, =_clkdivn
str r1, [r0, #oCLKDIVN]
mrc p15, 0, r1, c1, c0, 0 /* read ctrl register */
orr r1, r1, #0xc0000000 /* Asynchronous */
mcr p15, 0, r1, c1, c0, 0 /* write ctrl register */
/* UPLL setup */
ldr r1, =_upllcon
str r1, [r0, #oUPLLCON]
nop
nop
nop /* wait until upll has the effect */
nop
nop
/* PLL setup */
ldr r1, =_mpllcon
str r1, [r0, #oMPLLCON]
/* configure memory */
bl memset
/* Power Manage Check if this is a wake-up from sleep */
ldr r1, PMST_ADDR
ldr r0, [r1]
@bic r0,r0,#0xfffffffd
tst r0, #(0x02)
bne WakeupStart
WakeupStart:
/* Clear sleep reset bit */
ldr r0, PMST_ADDR
mov r1, #0x0 @PMST_SMR
str r1, [r0]
ldr r0, PMCTL1_ADDR /* Release the SDRAM signal protections */
ldr r1, =0x00010330
str r1, [r0]
ldr r0, =0x48000024
ldr r1, [r0]
bic r1, r1, #0x400000
str r1, [r0]
mov r1, #0x1000
1: subs r1, r1, #1 /* wait until the SelfRefresh is released. */
bne 1b
/* Go... */
ldr r0, =0x560000B8 /* read a return address go to s3c2410_cpu_resume*/
ldr r1, [r0]
mov pc, r1
nop
nop
1: b 1b /* infinite loop */
2、Kernel部分
1. 唤醒程序汇编部分(arch/arm/mach-s3c2410/sleep.s)
resume_with_mmu:
ldmfd sp!, { r4 - r12, pc }
.ltorg
.data
.global s3c2410_sleep_save_phys
s3c2410_sleep_save_phys:
.word 0
ENTRY(s3c2410_cpu_resume)
mov r0, #PSR_I_BIT | PSR_F_BIT | SVC_MODE
msr cpsr_c, r0
mov r2, #S3C24XX_PA_UART & 0xff000000
orr r2, r2, #S3C24XX_PA_UART & 0xff000
#if 0
/* SMDK2440 LED set */
mov r14, #S3C24XX_PA_GPIO
ldr r12, [ r14, #0x54 ]
bic r12, r12, #3<<4
orr r12, r12, #1<<7
str r12, [ r14, #0x54 ]
#endif
#ifdef CONFIG_DEBUG_RESUME
mov r3, #'L'
strb r3, [ r2, #S3C2410_UTXH ]
1001:
ldrb r14, [ r3, #S3C2410_UTRSTAT ]
tst r14, #S3C2410_UTRSTAT_TXE
beq 1001b
#endif /* CONFIG_DEBUG_RESUME */
mov r1, #0
mcr p15, 0, r1, c8, c7, 0 @@ invalidate I & D TLBs
mcr p15, 0, r1, c7, c7, 0 @@ invalidate I & D caches
ldr r0, s3c2410_sleep_save_phys @ address of restore block
ldmia r0, { r4 - r13 }
mcr p15, 0, r4, c15, c1, 0 @ CP access register
mcr p15, 0, r5, c13, c0, 0 @ PID
mcr p15, 0, r6, c3, c0, 0 @ Domain ID
mcr p15, 0, r7, c2, c0, 0 @ translation table base
mov r3, #'R'
#endif
ldr r2, =resume_with_mmu
mcr p15, 0, r8, c1, c0, 0 @ turn on MMU, etc
nop @ second-to-last before mmu
mov pc, r2 @ go back to virtual address
.ltorg |
