串口通信Verilog源程序(中)
串口通信Verilog源程序(中)
// UART RX Logic
Always @ (Posedge Rxclk Or Posedge Reset)
If (Reset) Begin
Rx_reg        <= 0;
Rx_data       <= 0;
Rx_sample_cnt <= 0;
Rx_cnt        <= 0;
Rx_frame_err <= 0;
Rx_over_run   <= 0;
Rx_empty      <= 1;
Rx_d1         <= 1;
Rx_d2         <= 1;
Rx_busy       <= 0;
End Else Begin
// Synchronize The Asynch Signal
Rx_d1 <= Rx_in;
Rx_d2 <= Rx_d1;
// Uload The Rx Data
If (Uld_rx_data) Begin
    Rx_data <= Rx_reg;
    Rx_empty <= 1;
End
// Receive Data Only When Rx Is Enabled
If (Rx_enable) Begin
    // Check If Just Received Start Of Frame
    If (!Rx_busy && !Rx_d2) Begin
      Rx_busy       <= 1;
      Rx_sample_cnt <= 1;
      Rx_cnt        <= 0;
    End
    // Start Of Frame Detected, Proceed With Rest Of Data
    If (Rx_busy) Begin
       Rx_sample_cnt <= Rx_sample_cnt + 1;
       // Logic To Sample At Middle Of Data
       If (Rx_sample_cnt == 7) Begin
          If ((Rx_d2 == 1) && (Rx_cnt == 0)) Begin
            Rx_busy <= 0;
          End Else Begin
            Rx_cnt <= Rx_cnt + 1;
            // Start Storing The Rx Data
            If (Rx_cnt > 0 && Rx_cnt < 9) Begin
              Rx_reg[Rx_cnt - 1] <= Rx_d2;
            End
            If (Rx_cnt == 9) Begin
               Rx_busy <= 0;
               // Check If End Of Frame Received Correctly
               If (Rx_d2 == 0) Begin
                 Rx_frame_err <= 1;
               End Else Begin
                 Rx_empty     <= 0;
                 Rx_frame_err <= 0;
                 // Check If Last Rx Data Was Not Unloaded,
                 Rx_over_run <= (Rx_empty) ? 0 : 1;
               End
            End
          End
       End
    End
End
If (!Rx_enable) Begin
    Rx_busy <= 0;
End
End
