效验位和停止位的设置:
无效验 | 8位 | Option.c_cflag &= ~PARENB;
Option.c_cflag &= ~CSTOPB;
Option.c_cflag &= ~CSIZE;
Option.c_cflag |= ~CS8; | 奇效验(Odd) | 7位 | Option.c_cflag |= ~PARENB;
Option.c_cflag &= ~PARODD;
Option.c_cflag |= ~CS7; | 偶效验(Even) | 7位 | Option.c_cflag &= ~PARENB;
Option.c_cflag |= ~PARODD;
Option.c_cflag |= ~CS7; | Space效验 | 7位 | Option.c_cflag &= ~PARENB;
Option.c_cflag &= &~CSIZE;
Option.c_cflag |= CS8; | 设置效验的函数:
/***@brief 设置串口数据位,停止位和效验位*@param fd 类型 int 打开的串口文件句柄*@param databits 类型 int 数据位 取值 为 7 或者8*@param stopbits 类型 int 停止位 取值为 1 或者2*@param parity 类型 int 效验类型 取值为N,E,O,,S*/int set_Parity(int fd,int databits,int stopbits,int parity){ struct termios options; if ( tcgetattr( fd,&options) != 0) { perror("SetupSerial 1"); return(FALSE); } options.c_cflag &= ~CSIZE; switch (databits) /*设置数据位数*/ { case 7: options.c_cflag |= CS7; break; case 8: options.c_cflag |= CS8; break; default: fprintf(stderr,"Unsupported data size\n"); return (FALSE); }switch (parity) { case 'n': case 'N': options.c_cflag &= ~PARENB; /* Clear parity enable */ options.c_iflag &= ~INPCK; /* Enable parity checking */ break; case 'o': case 'O': options.c_cflag |= (PARODD | PARENB); /* 设置为奇效验*/ options.c_iflag |= INPCK; /* Disnable parity checking */ break; case 'e': case 'E': options.c_cflag |= PARENB; /* Enable parity */ options.c_cflag &= ~PARODD; /* 转换为偶效验*/ options.c_iflag |= INPCK; /* Disnable parity checking */ break; case 'S': case 's': /*as no parity*/ options.c_cflag &= ~PARENB; options.c_cflag &= ~CSTOPB;break; default: fprintf(stderr,"Unsupported parity\n"); return (FALSE); } /* 设置停止位*/ switch (stopbits){ case 1: options.c_cflag &= ~CSTOPB; break; case 2: options.c_cflag |= CSTOPB; break; default: fprintf(stderr,"Unsupported stop bits\n"); return (FALSE); } /* Set input parity option */ if (parity != 'n') options.c_iflag |= INPCK; tcflush(fd,TCIFLUSH);options.c_cc[VTIME] = 150; /* 设置超时15 seconds*/ options.c_cc[VMIN] = 0; /* Update the options and do it NOW */if (tcsetattr(fd,TCSANOW,&options) != 0) { perror("SetupSerial 3"); return (FALSE); } return (TRUE); } |
需要注意的是:
如果不是开发终端之类的,只是串口传输数据,而不需要串口来处理,那么使用原始模式(Raw Mode)方式来通讯,设置方式如下:
options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG); /*Input*/options.c_oflag &= ~OPOST; /*Output*/ |
回页首
读写串口
设置好串口之后,读写串口就很容易了,把串口当作文件读写就是。
- 发送数据
char buffer[1024];int Length;int nByte;nByte = write(fd, buffer ,Length) |
- 读取串口数据 使用文件操作read函数读取,如果设置为原始模式(Raw Mode)传输数据,那么read函数返回的字符数是实际串口收到的字符数。
可以使用操作文件的函数来实现异步读取,如fcntl,或者select等来操作。
char buff[1024];int Len;int readByte = read(fd,buff,Len); |
回页首
关闭串口
关闭串口就是关闭文件。
close(fd); |
