U-boot、内核移植、根文件系统的构建(s3c2440)(2)
static int strtonum(char *str)
              return (*str-48);
int do_led (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
       S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO();
       int i=0;
       int j=0;
       if(argc != 3)
              printf("led led_num on/off\n");
              return 1;
       if(strtonum(argv[1])>3||strtonum(argv[1])<0)
                     printf("only have 3 leds,please input 0-3\n")  ;
                     return 1;
       if(strtonum (argv[2])==1)
                     j=strtonum(argv[1])+5;
                     i=1<<j;
                     gpio->GPBDAT= (gpio->GPBDAT)&(~i);
       else if(strtonum (argv[2])==0)
                     i=1<<j;
                     gpio->GPBDAT= (gpio->GPBDAT)|i;
       else
              printf("bad command,1:led on,0:led off\n");
              return 1;
       return 0;
U_BOOT_CMD(
      led,  CFG_MAXARGS,  1,    do_led,
      "led   - trun on or off the leds\n",
#endif
2 修改/include/cmd_confdefs.h
#define CFG_CMD_LED     0x8000000000000000ULL
3 修改本层Makefile文件,增加cmd_led.o
4 增加自动挂载功能
#define CONFIG_BOOTCOMMAND   "nand read.jffs2 0x32000000 0x80000 0x180000; bootm 0x32000000"
5 增加历史纪录
#define CONFIG_CMDLINE_EDITING      1     /* add command line history  */
************引导linux启动***************
1 在/include/configs/my2440.h中增加宏定义
#define CONFIG_CMDLINE_TAG
#define CONFIG_SETUP_MEMORY_TAGS
继承事业,薪火相传
