伪随机数产器VHDL源程序-1
伪随机数产器VHDL源程序-1
--      The Following Information Has Been Generated By Exemplar Logic And
May Be Freely Distributed And Modified.
--      Design Name : Pseudorandom   Purpose : This Design Is A Pseudorandom Number Generator. This Design  Will Generate An 8-Bit Random Number Using The Polynomial P(X) = X + 1.
--        This System Has A Seed Generator And Will Generate 2**8 - 1 Unique
--        Vectors In Pseudorandom Order. These Vectors Are Stored In A RAM Which
--        Samples The Random Number Every 32 Clock Cycles. This Variance Of A
--        Priority Encoded Seed Plus A Fixed Sampling Frequency Provides A Truely
--        Random Number.
--        This Design Used VHDL-1993 Methods For Coding VHDL.
Library IEEE ;
Use IEEE.Std_logic_1164.All ;
Use IEEE.Std_logic_arith.All ;
Entity Divide_by_n Is
   Generic (Data_width    : Natural := 8 );
   Port (
         Data_in  : In  UNSIGNED(Data_width - 1 Downto 0) ;
         Load     : In  Std_logic ;
         Clk      : In  Std_logic ;
         Reset    : In  Std_logic ;
         Divide   : Out Std_logic
End Divide_by_n ;
Architecture Rtl Of Divide_by_n Is
  Signal Count_reg : UNSIGNED(Data_width - 1 Downto 0) ;
  Constant Max_count : UNSIGNED(Data_width - 1 Downto 0) := (Others => ''1'') ;
  Begin
  Cont_it :  Process(Clk,Reset)
       Begin
          If (Reset = ''1'') Then
           Count_reg <= (Others => ''0'') ;
          Elsif (Clk = ''1'' And Clk''Event) Then
            If (Load = ''1'') Then
               Count_reg <= Data_in ;
            Else
                Count_reg <=  Count_reg + "01" ;
            End If ;
          End If;
        End Process ;
   Divide <= ''1'' When Count_reg = Max_count Else ''0'' ;
End RTL ;
Library IEEE ;
Entity Dlatrg Is
   Generic (Data_width    : Natural := 16 );
   Port (
         Data_out : Out UNSIGNED(Data_width - 1 Downto 0)
End Dlatrg ;
Architecture Rtl Of Dlatrg Is
  Begin
  Latch_it : Process(Data_in,Clk,Reset)
        Begin
            Data_out <= (Others => ''0'') ;
          Elsif (Clk = ''1'') Then
            Data_out <= Data_in ;
          End If;
        End Process ;
End RTL ;
Library IEEE ;
Entity Lfsr Is
   Port (
End Lfsr ;
Architecture Rtl Of Lfsr Is
  Signal Feedback : Std_logic ;
  Signal Lfsr_reg : UNSIGNED(Data_width - 1 Downto 0) ;
  Begin
    Feedback <= Lfsr_reg(7) Xor Lfsr_reg(0) ;
  Latch_it :  Process(Clk,Reset)
       Begin
           Lfsr_reg <= (Others => ''0'') ;
            Lfsr_reg <= Lfsr_reg(Lfsr_reg''High - 1 Downto 0) & Feedback ;
          End If;
        End Process ;
   Data_out <= Lfsr_reg ;
End RTL ;
Library IEEE ;
Entity Priority_encoder Is
   Generic (Data_width    : Natural := 25 ;
            Address_width : Natural := 5 ) ;
   Port (
         Data    : In  UNSIGNED(Data_width - 1 Downto 0) ;
         Address : Out UNSIGNED(Address_width - 1 Downto 0) ;
         None    : Out STD_LOGIC
End Priority_encoder ;
Architecture Rtl Of Priority_encoder Is
  Attribute SYNTHESIS_RETURN : STRING ;
  FUNCTION To_stdlogic (Arg1:BOOLEAN)  RETURN STD_LOGIC IS
      BEGIN
      IF(Arg1) THEN
        RETURN(''1'') ;
      ELSE
        RETURN(''0'') ;
      END IF ;
  END ;
