伪随机数产器VHDL源程序-3
伪随机数产器VHDL源程序-3
Architecture Rtl Of Tbuf Is
  Begin
  Three_state :  Process(Data_in,En)
        Begin
          If (En = ''1'') Then
            Data_out <=  Data_in ;
          Else
            Data_out <= (Others => ''Z'') ;
          End If;
        End Process ;
End RTL ;
Library IEEE ;
Use IEEE.Std_logic_1164.All ;
Use IEEE.Std_logic_arith.All ;
Entity Pseudorandom Is
   Generic (Data_width    : Natural := 8 );
   Port (
         Seed   : In  UNSIGNED (24 Downto 0) ;
         Init   : In  UNSIGNED (4 Downto 0) ;
         Load   : In  Std_logic ;
         Clk    : In  Std_logic ;
         Reset  : In  Std_logic ;
         Read   : In  Std_logic ;
         Write  : In  Std_logic ;
         Rand   : Out UNSIGNED (7 Downto 0) ;
         None   : Out Std_logic
End Pseudorandom ;
Architecture Rtl Of Pseudorandom Is
  Signal Latch_seed : UNSIGNED(24 Downto 0) ;
  Signal Encoder_address : UNSIGNED(4 Downto 0) ;
  Signal Random_data : UNSIGNED(7 Downto 0) ;
  Signal Write_enable : Std_logic ;
  Signal Ram_data : UNSIGNED(7 Downto 0) ;
  Begin
    I0 : Entity Work.Dlatrg(Rtl)
          Generic Map (25)
          Port Map (Seed,Read,Reset,Latch_seed) ;
    I1 : Entity Work.Priority_encoder(Rtl)
          Generic Map (25,5)
          Port Map (Latch_seed,Encoder_address,None) ;
    I2 : Entity Work.Ram(Rtl)
          Generic Map (8,5)
          Port Map (Random_data,Encoder_address,Write_enable,Clk,Ram_data) ;
    I3 : Entity Work.Tbuf(Rtl)
          Generic Map (8)
          Port Map (Ram_data,Write,Rand) ;
    I4 : Entity Work.Lfsr(Rtl)
          Generic Map (8)
          Port Map (Clk,Reset,Random_data) ;
     I5 : Entity Work.Divide_by_n(Rtl)
          Generic Map (5)
          Port Map (Init,Load,Clk,Reset,Write_enable) ;
End Rtl ;
