-- This Design Implements A UART.
-- Version 1.1 : Original Creation
-- Version 1.2 : Modified To Std_logic Types
-- Version 2.1 : Extended Reset To Be More Effective.
-- Introduced OTHERS Clause.
LIBRARY Ieee;
Use Ieee.Std_logic_1164.All;
Use Ieee.Std_logic_arith.All;
Use Ieee.Std_logic_unsigned.All;
ENTITY Uart IS
PORT (Clkx16 : IN Std_logic; -- Input Clock. 16x Bit Clock
Read : IN Std_logic; -- Received Data Read Strobe
Write : IN Std_logic; -- Transmit Data Write Strobe
Rx : IN Std_logic; -- Receive Data Line
Reset : IN Std_logic; -- Clear Dependencies
Tx : OUT Std_logic; -- Transmit Data Line
Rxrdy : OUT Std_logic; -- Received Data Ready To Be Read
Txrdy : OUT Std_logic; -- Transmitter Ready For Next Byte
Parityerr : OUT Std_logic; -- Receiver Parity Error
FRAMingerr : OUT Std_logic; -- Receiver Framing Error
Overrun : OUT Std_logic; -- Receiver Overrun Error
Data : INOUT Std_logic_vector(0 TO 7)); -- Bidirectional Data Bus
END Uart;
ARCHITECTURE Exemplar OF Uart IS
-- Transmit Data Holding Register
SIGNAL Txhold : Std_logic_vector(0 TO 7);
-- Transmit Shift Register Bits
SIGNAL Txreg : Std_logic_vector(0 TO 7);
SIGNAL Txtag2 : Std_logic; -- Tag Bits For Detecting
SIGNAL Txtag1 : Std_logic; -- Empty Shift Reg
SIGNAL Txparity : Std_logic; -- Parity Generation Register
-- Transmit Clock And Control Signals
SIGNAL Txclk : Std_logic; -- Transmit Clock: 1/16th Of Clkx16
SIGNAL Txdone : Std_logic; -- ''1'' When Shifting Of Byte Is Done
SIGNAL Paritycycle : Std_logic; -- ''1'' On Next To Last Shift Cycle
SIGNAL Txdatardy : Std_logic; -- ''1'' When Data Is Ready In Txhold
-- Receive Shift Register Bits
SIGNAL Rxhold : Std_logic_vector(0 TO 7);-- Holds Received Data For Read
SIGNAL Rxreg : Std_logic_vector(0 TO 7);-- Receive Data Shift Register
SIGNAL Rxparity : Std_logic; -- Parity Bit Of Received Data
SIGNAL Paritygen : Std_logic; -- Generated Parity Of Received Data
SIGNAL Rxstop : Std_logic; -- Stop Bit Of Received Data
-- Receive Clock And Control Signals
SIGNAL Rxclk : Std_logic; -- Receive Data Shift Clock
SIGNAL Rxidle : Std_logic; -- ''1'' When Receiver Is Idling
SIGNAL Rxdatardy : Std_logic; -- ''1'' When Data Is Ready To Be Read
BEGIN
Make_txclk:
PROCESS (Reset, Clkx16)
VARIABLE Cnt : Std_logic_vector(2 DOWNTO 0);
BEGIN
-- Toggle Txclk Every 8 Counts, Which Divides The Clock By 16
IF Reset=''1'' THEN
Txclk <= ''0'' ;
Cnt := (OTHERS=>''0'') ;
ELSIF Clkx16''Event AND Clkx16=''1'' THEN
IF (Cnt = "000") THEN
Txclk <= NOT Txclk;
END IF;
Cnt := Cnt + "001"; -- Use The Exemplar_1164 "+" On Std_logic_vector
END IF;
END PROCESS;
Make_rxclk:
VARIABLE Rxcnt : Std_logic_vector(0 TO 3); -- Count Of Clock Cycles
VARIABLE Rx1 : Std_logic; -- Rx Delayed One Cycle
VARIABLE Hunt : Boolean; -- Hunting For Start Bit
BEGIN
IF Reset=''1'' THEN
-- Reset All Generated Signals And Variables
Hunt := FALSE ;
Rxcnt := (OTHERS=>''0'') ;
Rx1 := ''0'' ;
Rxclk <= ''0'' ;
ELSIF Clkx16''EVENT AND Clkx16 = ''1'' THEN
-- Rxclk = Clkx16 Divided By 16
Rxclk <= Rxcnt(0);
-- Hunt=TRUE When We Are Looking For A Start Bit:
-- A Start Bit Is Eight Clock Times With Rx=0 After A Falling Edge
IF (Rxidle = ''1'' AND Rx = ''0'' AND Rx1 = ''1'') THEN
-- Start Hunting When Idle And Falling Edge Is Found
Hunt := TRUE;
END IF ;
IF Rxidle = ''0'' OR Rx = ''1'' THEN
-- Stop Hunting When Shifting In Data Or A 1 Is Found On Rx
Hunt := FALSE;
END IF;
Rx1 := Rx; -- Rx Delayed By One Clock For Edge Detection
-- (Must Be Assigned AFTER Reference)
-- Increment Count When Not Idling Or When Hunting
IF (Rxidle = ''0'' OR Hunt) THEN
-- Count Clocks When Not Rxidle Or Hunting For Start Bit
Rxcnt := Rxcnt + "0001";
ELSE
-- Hold At 1 When Rxidle And Waiting For Falling Edge
Rxcnt := "0001";
END IF;
END IF ;
END PROCESS; |
