如何使用STATECAD进行多状态机设计实例分析-2
-- D:XILINXTUTORIALDUOZTJI.Vhd
LIBRARY Ieee;
USE Ieee.Std_logic_1164.All;
LIBRARY Ieee;
USE Ieee.Std_logic_unsigned.All;
ENTITY SHELL_DUOZTJI IS
PORT (CLK,RESET: IN Std_logic;
Dcounter0,Dcounter1 : OUT Std_logic);
SIGNAL BP_dcounter0,BP_dcounter1,Readcounter0,Readcounter1: Std_logic;
END;
ARCHITECTURE BEHAVIOR OF SHELL_DUOZTJI IS
SIGNAL Sreg : Std_logic_vector (1 DOWNTO 0);
SIGNAL Next_sreg : Std_logic_vector (1 DOWNTO 0);
CONSTANT M0full : Std_logic_vector (1 DOWNTO 0) :="00";
CONSTANT M0writewait : Std_logic_vector (1 DOWNTO 0) :="01";
CONSTANT STATE0 : Std_logic_vector (1 DOWNTO 0) :="10";
CONSTANT Write0 : Std_logic_vector (1 DOWNTO 0) :="11";
SIGNAL Sreg1 : Std_logic_vector (1 DOWNTO 0);
SIGNAL Next_sreg1 : Std_logic_vector (1 DOWNTO 0);
CONSTANT M0empty : Std_logic_vector (1 DOWNTO 0) :="00";
CONSTANT M0readwait : Std_logic_vector (1 DOWNTO 0) :="01";
CONSTANT Read0 : Std_logic_vector (1 DOWNTO 0) :="10";
CONSTANT STATE1 : Std_logic_vector (1 DOWNTO 0) :="11";
SIGNAL Next_BP_dcounter0,Next_BP_dcounter1,Next_readcounter0,
Next_readcounter1 : Std_logic;
SIGNAL BP_dcounter : Std_logic_vector (1 DOWNTO 0);
SIGNAL Dcounter : Std_logic_vector (1 DOWNTO 0);
SIGNAL Readcounter : Std_logic_vector (1 DOWNTO 0);
BEGIN
PROCESS (CLK, Next_sreg, Next_BP_dcounter1, Next_BP_dcounter0)
BEGIN
IF CLK=''1'' AND CLK''Event THEN
Sreg <= Next_sreg;
BP_dcounter1 <= Next_BP_dcounter1;
BP_dcounter0 <= Next_BP_dcounter0;
END IF;
END PROCESS;
PROCESS (CLK, Next_sreg1, Next_readcounter1, Next_readcounter0)
BEGIN
Sreg1 <= Next_sreg1;
Readcounter1 <= Next_readcounter1;
Readcounter0 <= Next_readcounter0;
END IF;
END PROCESS;
PROCESS (Sreg,Sreg1,BP_dcounter0,BP_dcounter1,Readcounter0,Readcounter1,
RESET,BP_dcounter,Readcounter)
BEGIN
Next_BP_dcounter0 <= BP_dcounter0;Next_BP_dcounter1 <= BP_dcounter1;
Next_readcounter0 <= Readcounter0;Next_readcounter1 <= Readcounter1;
BP_dcounter <= (( Std_logic_vector''(BP_dcounter1, BP_dcounter0)));
Readcounter <= (( Std_logic_vector''(Readcounter1, Readcounter0)));
Next_sreg<=M0full;
Next_sreg1<=M0empty;
IF ( RESET=''1'' ) THEN
Next_sreg<=STATE0;
BP_dcounter <= (Std_logic_vector''("00"));
ELSE
CASE Sreg IS
WHEN M0full =>
Next_sreg<=M0writewait;
WHEN M0writewait =>
IF ( (Sreg1=M0empty)) THEN
Next_sreg<=Write0;
BP_dcounter <= (( Std_logic_vector''(BP_dcounter1, BP_dcounter0)) + Std_logic_vector''("01"));
ELSE
END IF;
WHEN STATE0 =>
Next_sreg<=Write0;
WHEN Write0 =>
IF ( BP_dcounter0=''1'' AND BP_dcounter1=''1'' ) THEN
Next_sreg<=M0full;
ELSE
Next_sreg<=Write0;
END IF;
WHEN OTHERS =>
END CASE;
END IF;
Next_sreg1<=STATE1;
Readcounter <= (Std_logic_vector''("00"));
ELSE
CASE Sreg1 IS
WHEN M0empty =>
Next_sreg1<=M0readwait;
WHEN M0readwait =>
IF ( (Sreg=M0full)) THEN
Next_sreg1<=Read0;
Readcounter <= (( Std_logic_vector''(Readcounter1, Readcounter0)) +
ELSE
END IF;
WHEN Read0 =>
IF ( Readcounter0=''1'' AND Readcounter1=''1'' ) THEN
ELSE
Next_sreg1<=Read0;
END IF;
WHEN STATE1 =>
Next_sreg1<=Read0;
Readcounter <= (( Std_logic_vector''(Readcounter1, Readcounter0)) + Std_logic_vector''("01"));
ELSE
Next_sreg1<=STATE1;
END IF;
WHEN OTHERS =>
END CASE;
END IF;
Next_BP_dcounter1 <= BP_dcounter(1);
Next_BP_dcounter0 <= BP_dcounter(0);
Next_readcounter1 <= Readcounter(1);
Next_readcounter0 <= Readcounter(0);
END PROCESS;
PROCESS (BP_dcounter0,BP_dcounter1,Dcounter)
BEGIN
Dcounter <= (( Std_logic_vector''(BP_dcounter1, BP_dcounter0)));
Dcounter0 <= Dcounter(0);
Dcounter1 <= Dcounter(1);
END PROCESS;
END BEHAVIOR;
LIBRARY Ieee;
LIBRARY Ieee;
ENTITY DUOZTJI IS
PORT (Dcounter : OUT Std_logic_vector (1 DOWNTO 0);
CLK,RESET: IN Std_logic);
END;
ARCHITECTURE BEHAVIOR OF DUOZTJI IS
COMPONENT SHELL_DUOZTJI
END COMPONENT;
BEGIN
SHELL1_DUOZTJI : SHELL_DUOZTJI PORT MAP (CLK=>CLK,RESET=>RESET,Dcounter0=>
Dcounter(0),Dcounter1=>Dcounter(1));
END BEHAVIOR; |
