先入先出(FIFO)缓冲区算法(2)
先入先出(FIFO)缓冲区算法(2)
return   size;
int   MyBuf::read(int   size,   char*   buf)
assert(size   >   0);
if   (size   >   m_size)   return   -1;
int   n   =   getBufferEnd()   -   m_head;
if   (n   > =   size){
memcpy(buf,   m_head,   size);
m_head   +=   size;
}else{
memcpy(buf,   m_head,   n);
memcpy(buf   +   n,   m_buf,   size   -   n);
m_head   =   m_buf   +   size   -   n;
m_size   -=   size;
if   (m_size   ==   0)   m_head   =   m_buf;
return   size;
int   main()
MyBuf   buf(12);
char   tmp[100];
buf.write( "abchello ",   (int)sizeof( "abchello ")   -   1);
buf.read(tmp,   3);
tmp[3]   =   0;
cout   < <   tmp   < <   endl;
buf.write( "   world! ",   (int)sizeof( "   world! ")   -   1);
buf.read(tmp,   12);
tmp[12]   =   0;
return   0;
#define   BUFFER_SIZE   (unsigned   long   )10000000
unsigned   char   BUFFER[BUFFER_SIZE]   =   {0};
unsigned   char   *pBufferFront     =   (unsigned   char   *)BUFFER;
unsigned   char   *pBuffereEnd   =   (unsigned   char   *)BUFFER   +BUFFER_SIZE   -1;
unsigned   char   *pBufferCur   =   pBufferFront;
unsigned   char   Buffer_Put(unsigned   long   put_size,unsigned   char   *put_pointer)
unsigned   long   current_size;
unsigned   long   count;
if(put_size   >   (pBufferCur   -   pBufferFront))
return   FALSE;
for(count   =   0;count <put_size;count++)
*pBufferCur--   =   *put_pointer++;
unsigned   char   Buffer_Get(unsigned   long   get_size,unsigned   char   *get_pointer)
unsigned   char   *move_pointer   =   pBuffereEnd;
if(get_size> BUFFER_SIZE-   pBufferCur)
return   FALSE;
for(count   =   0;count <get_size;count++)
*get_pointer++   =   *move_pointer--;
for(count   =   0,pBufferCur   =   pBuffereEnd;count   <   move_pointer   -   pBufferCur;count++)
              *pBufferCur--   =   *move_pointer--;
return   TRUE;
继承事业,薪火相传
