基于Arduino的LPD6803 LED驱动器(含源码)
#Include
#Include "LPD6803.H"
Int InByte;
Int DataPin = 2; // 'Yellow' Wire
Int ClockPin = 3; // 'Green' Wire
LPD6803 Strip = LPD6803(5, DataPin, ClockPin);
Void Setup() {
Serial.Begin(9600);
Strip.SetCPUmax(50); // Start With 50% CPU Usage. Up This If The Strand Flickers Or Is Slow
Strip.Begin();
Strip.Show();
Void Loop() {
If(Serial.Available()){
InByte = Serial.Read();
Switch(InByte){
Case 0x1:
Runrunrun(Color(31, 0, 0), 50);
Break;
Case 0x2:
Runrunrun(Color(62, 0, 0), 50);
Break;
Case 0x3:
Runrunrun(Color(93, 0, 0), 50);
Break;
Case 0x11:
ColorWipe(Color(63, 0, 0), 50);
ColorWipe(Color(0, 63, 0), 50);
ColorWipe(Color(0, 0, 63), 50);
Break;
Case 0x22:
Rainbow(50);
Break;
Case 0x33:
RainbowCycle(50);
Break;
Void Rainbow(Uint8_t Wait) {
Int I, J;
For (J=0; J < 96 * 3; J++) { // 3 Cycles Of All 96 Colors In The Wheel
For (I=0; I < Strip.NumPixels(); I++) {
Strip.SetPixelColor(I, Wheel( (I + J) % 96));
Strip.Show(); // Write All The Pixels Out
Delay(Wait);
// Slightly Different, This One Makes The Rainbow Wheel Equally Distributed
// Along The Chain
Void RainbowCycle(Uint8_t Wait) {
Int I, J;
For (J=0; J < 96 * 5; J++) { // 5 Cycles Of All 96 Colors In The Wheel
// Tricky Math! We Use Each Pixel As A Fraction Of The Full 96-Color Wheel
// (Thats The I / Strip.NumPixels() Part)
// Then Add In J Which Makes The Colors Go Around Per Pixel
// The % 96 Is To Make The Wheel Cycle Around
Strip.SetPixelColor(I, Wheel( ((I * 96 / Strip.NumPixels()) + J) % 96) );
Delay(Wait);
// Fill The Dots One After The Other With Said Color
// Good For Testing Purposes
Void Runrunrun(Uint16_t C, Uint8_t Wait) {
Void ColorWipe(Uint16_t C, Uint8_t Wait) {
Int I;
Strip.SetPixelColor(I, C);
Strip.Show();
Delay(Wait);
/* Helper Functions */
// Create A 15 Bit Color Value From R,G,B
Unsigned Int Color(Byte R, Byte G, Byte B)
//Take The Lowest 5 Bits Of Each Value And Append Them End To End
Return( ((Unsigned Int)G & 0x1F )<<10 | ((Unsigned Int)B & 0x1F)<<5 | (Unsigned Int)R & 0x1F);
//Input A Value 0 To 127 To Get A Color Value.
//The Colours Are A Transition R - G -B - Back To R
Unsigned Int Wheel(Byte WheelPos)
Byte R,G,B;
Switch(WheelPos >> 5)
Case 0:
R=31- WheelPos % 32; //Red Down
G=WheelPos % 32; // Green Up
B=0; //Blue Off
Break;
Case 1:
G=31- WheelPos % 32; //Green Down
B=WheelPos % 32; //Blue Up
R=0; //Red Off
Break;
Case 2:
B=31- WheelPos % 32; //Blue Down
R=WheelPos % 32; //Red Up
G=0; //Green Off
Break;
Return(Color(R,G,B));
Terminal Software: Coolterm [Link]
Reference:
Timer Page [Link]
All LPD6803 Lib Files [Link]
