[求助]无法下载到目标板上~
[求助]无法下载到目标板上~
我用QuartusII做的一个简单设计,在编译完成后出现下列对话框:
File_mydesign_time_limited.sof contains one or more time_limited megafunctions that support the OpenCore plus feature that will not work after the harework evaluation time expires. Refer to the massages windows for evaluation time details.
无法下载到目标板上,消息窗口如下:
Info: Started Full Compilation at Fri Mar 30 09:55:43 2007
Info: Ended Full Compilation at Fri Mar 30 09:58:45 2007
Info: SRAM Object File mydesign_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A2
Info: Started Programmer operation at Fri Mar 30 10:03:06 2007
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020B40DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Fri Mar 30 10:03:08 2007
不知怎么回事?哪位高手指教一下,谢谢~~~
你有一个或几个IP过期了!你可以重新找破解,好像本版就有。
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
好的,谢谢版主~
重新破解还是不行啊……
上面的问题还是存在,无法下载到目标板上,出现下列对话框:
Click cancel to stop using Opencore plus IP
Time remaining unlimited
消息窗口如下:
Info: SRAM Object File mydesign_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -Vendor: 0x6AF7, Product: 0x00A2
版主版主在不在啊??
我出现了同样的问题...
请高人指点,谢谢!
你的license有问题啊,重新找一个license,保证所有的core都可以用,就可以了。
在交流中前进,共同实现nios的应用。
我也一样,楼主你的问题有解决了没有啊?
