ARM DDR SDRAM 初始化(2)
int sdram_init(
void
// tell dramc to configure
set_val( MEMCCMD, 0x4 );
// set refresh period
set_val( P1REFRESH, nstoclk(7800) );
// set timing para
set_val( P1CASLAT, ( 3 << 1 ) );
set_val( P1T_DQSS, 0x1 );
// 0.75 - 1.25
set_val( P1T_MRD, 0x2 );
set_val( P1T_RAS, nstoclk(45) );
set_val( P1T_RC, nstoclk(68) );
u32 trcd = nstoclk(
23
set_val( P1T_RCD, trcd |
(( trcd -
3
3
u32 trfc = nstoclk(
80
set_val( P1T_RFC, trfc |
( trfc-3
5
u32 trp = nstoclk(
23
set_val( P1T_RP, trp |
( trp -
3
3
set_val( P1T_RRD, nstoclk(15)
set_val( P1T_WR, nstoclk(15)
set_val( P1T_WTR,
0x7
set_val( P1T_XP,
0x2
set_val( P1T_XSR, nstoclk(120)
set_val( P1T_ESR, nstoclk(120)
// set mem cfg
set_nbit( P1MEMCFG, 0, 3, 0x2 );  /* 10 column address */
/* set_nbit: 把从第bit位开始的一共len位消零,然后把这几位设为val */
set_nbit( P1MEMCFG,
3,
3,
0x2
/* 13 row address */
set_zero( P1MEMCFG,
6
/* A10/AP */
set_nbit( P1MEMCFG,
15,
3,
0x2
/* Burst 4 */
set_nbit( P1MEMCFG2,
0,
4,
0x5
set_2bit( P1MEMCFG2,
6,
0x1
/* 32 bit */
8,
3,
0x3
/* Mobile DDR SDRAM */
11,
0x1
set_one( P1_chip_0_cfg,
16
/* Bank-Row-Column organization */
// memory init
set_val( P1DIRECTCMD, 0xc0000 ); // NOP
set_val( P1DIRECTCMD, 0x000 );
// precharge
set_val( P1DIRECTCMD, 0x40000 );// auto refresh
set_val( P1DIRECTCMD, 0xa0000 ); // EMRS
set_val( P1DIRECTCMD, 0x80032 ); // MRS
set_val( MEM_SYS_CFG,
0x0
// set dramc to "go" status
set_val( P1MEMCCMD, 0x000 );
// wait ready
while( !(( read_val( P1MEMSTAT ) & 0x3 ) == 0x1));
继承事业,薪火相传
