一般程序都只有一个入口地址,main,但是为了程序的初始化方便或利用继承性(c++)中,定义了main的别名,这里的程序入口你可以想象成alt_main()是main()函数的内部隐藏带有驱动的入口。区别看了就知道了。 请看下面的程序 /* Copyright ?2004 Altera Corporation, San Jose, California, USA. All rights * reserved. All use of this software and documentation is subject to the License * Agreement located at the end of this file below. ****************************************************************************** * DANGER ** WARNING ** Please read before proceeding! ** WARNING ** DANGER * ****************************************************************************** * * "Hello World Free-Standing" (hello_alt_main) example. * * This program is an example of a "free-standing" C application since it * calls "alt_main()" instead of "main()". The example's purpose is to * illustrate to the advanced embedded developer the low-level system * initialization steps needed for a "Hello World" type application. By * calling "alt_main()" instead of "main()", these system initialization steps * are NOT linked in automatically, and must be provided by the developer, * which this example illustrates. * * Please refer to file readme.txt for notes on this software example. */ #include <stdio.h> #include <stdlib.h> #include "system.h" #include "sys/alt_sys_init.h" #include "sys/alt_irq.h" #include "priv/alt_file.h" /* * The following statement defines "main()" so that when the Nios II IDE * debugger is set to break at "main()", it will break at the appropriate * place in this program, which does not contain a function called "main()". * Note that the Nios II IDE debugger can also be set to break at "alt_main()", * in which case the following statement would be unneccessary since * "alt_main()" is defined in this program. */ int main (void) __attribute__ ((weak, alias ("alt_main"))); /* * _do_ctors() is used to call the C++ constructors. * * It is declared weak so that we don't have to force * inclusion of _do_ctors if there are no C++ constructors * to call. * * Commended out here because this example is not a C++ program: */ //extern void _do_ctors(void) ALT_WEAK;
int alt_main(void) { /* * Enable Interrutps * * Turn on interrupts, and initialize the low-level interrupt handler: */ alt_irq_init (ALT_IRQ_BASE); /* * Device-Driver Initialization * * Initialize all the device drivers for every piece of hardware * in the current system. * * Note that the function "alt_sys_init()" is defined in the * AUTOMATICALLY-GENERATED file alt_sys_init.c. This file is * generated "on the fly" into your System Library project * at library-build time (as part of the Make-process). You can find the * file here: * <system library name>/Release/system_description/alt_sys_init.c * * Because it is generated on-the-fly, your library's copy of * alt_sys_init() is customized to initialize *only* the devices * in your *particuilar* Nios II system. * * Being machine-generated, alt_sys_init() initializes every single * device in your system--even ones which your application may not * use. Indeed, this "Hello World" program only uses one--the * STDOUT device. If you wish to save code-space, you may want * to initialize only the devices you actually need and use. * * To do so, you should define your own function (e.g. small_sys_init()). * DO NOT edit the file alt_sys_init.c! If you do, your changes will be * overwritten the next time you build the library! Please refer to the * "readme.html" file that accompanies this software example to see how * such a customized sys_init routine would look for UART initialization ONLY. */ alt_sys_init();
/* * I/O Stream Initialization. * * Initialize the STDOUT stream, and associate it with the * System Library's designated STDOUT device. Note that the symbols * ALT_STDOUT (etc) are defined in the (generated) file system.h. * */ alt_io_redirect (ALT_STDOUT, ALT_STDIN, ALT_STDERR);
/* * C++ Constructors. * * This particular example is not a C++ program. But, if it were, * you would need to call all your static constructors as part of * the initialization process. To do so, you would un-comment this * line: * */ //_do_ctors();
printf("Hello from Nios II Free-Standing!\n");
/* * Exit gracefully. * * Many embedded programs run as long as the machine is powered-up. * Those programs don't need to call exit(). But even this humble * little "Hello World" application (which, indeed, does terminate) * needs to call exit(). The exit() function, amongst many other * things, flushes the I/O buffers--a singularly-important service * for this example: */ exit(0); // Return code for "success!" if anyone is checking (they aren't). } /****************************************************************************** * * * License Agreement * * * * Copyright (c) 2004 Altera Corporation, San Jose, California, USA. * * All rights reserved. * * * * Permission is hereby granted, free of charge, to any person obtaining a * * copy of this software and associated documentation files (the "Software"), * * to deal in the Software without restriction, including without limitation * * the rights to use, copy, modify, merge, publish, distribute, sublicense, * * and/or sell copies of the Software, and to permit persons to whom the * * Software is furnished to do so, subject to the following conditions: * * * * The above copyright notice and this permission notice shall be included in * * all copies or substantial portions of the Software. * * * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE * * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER * * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING * * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER * * DEALINGS IN THE SOFTWARE. * * * * This agreement shall be governed in all respects by the laws of the State * * of California and by the laws of the United States of America. * * Altera does not recommend, suggest or require that this reference design * * file be used in conjunction or combination with any other product. * * ******************************************************************************/ |
