uchar AD_Filter(void){
uchar i;
uchar cTemp[32];
uchar cAverage; for(i=32;i>0;i--){
cTemp=Ad_Change(0);
cAverage=((cAverage+cTemp)>>1);
return(cAverage);
void InitCom(unsigned char BaudRate){
switch (BaudRate){
case 1: THTL = 64; break; //波特率300
case 2: THTL = 160; break; //600
case 3: THTL = 208; break; //1200
case 4: THTL = 232; break; //2400
case 5: THTL = 244; break; //4800
case 6: THTL = 250; break; //9600
case 7: THTL = 253; break; //19200
case 8: THTL = 255; break; //57600
default: THTL = 208; break; //1200
void Chip_initial(void){
IE=0;
// 定时器控制字初始化
TMOD=0x21; //定时器1为方式2,定时器0为方式1
TCON=0x50; //设置外部中断类型
T2CON=0x0d; //选择定时器1为波特率发生器,T2为捕获工作方式
// ET2=1;
ET0=1; //允许定时器0、定时器2中断
//外部中断设置
EX0=0; //FFSK中断初始时关闭,有载波时再开启
EX1=0;
IT1=1; //外部中断0、1均为下降沿触发
IT0=1;
//启动定时器0
TH0=vT0HVal; //启动定时器0
TL0=vT0LVal;
TR0=1;
InitCom(6); //设置波特率为96001-7波特率300-19200
SCON = 0x50; //串口方式1,允许接收
TH1 = THTL;
TL1 = THTL;
PCON = 0x80; //波特率加倍控制,SMOD位
RI =0; //清收发标志
TI = 0;
TR1 =1; //启动定时器
IP=0x02; //PT2=1
IPH=0x02; //PT2H=1,PT0H=1
EA=1;
delay_ms(10); //延时是为了避免定时器0无法产生中断的问题
void Para_initial(void){
OutFlag=0;
cT01ms = vT01ms;
cT10ms = vT10ms;
// cT100ms = vT100ms;
cT01s = vT01S;
CS = 0; //设置CS为0不选任何的音源,如为1则选第1路
void system_initial(void){
Chip_initial();
Para_initial();
DogReset(); // 已针对 STC89C58RD+作修改.06-04-06
void main(void){
system_initial();
while(1){
DogReset();
if(OutFlag){
OutFlag=0;
send_char_com(AD_Filter());
void Trint0(void) interrupt 1 using 1{
TR0=0; //时基1mS
TH0=vT0HVal;
TL0=vT0LVal;
TR0=1;
TF0=0;
if(!(--cT01ms)){
cT01ms=vT01ms;
if(!(--cT10ms)){
cT10ms=vT10ms;
if(!(--cT01s)){
cT01s=vT01S;
OutFlag=1;
void ComInINT(void)interrupt 4 {
if (RI){ //判断是不收完字符
switch(SBUF){
case 0x61: CS= 1; break; //根据SBUF设置CS 接收'abcde'调试方便
case 0x62: CS= 2; break;
case 0x63: CS= 3; break;
case 0x64: CS= 4; break;
case 0x65: CS= 0; break;
P1 = 255;//P1口全为高电平,4-7通过反相为低不选任何音源,0-3为高用于读取按键
RI = 0; //RI清零
