uint8_t I2C_Read(uint8_t addr)
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
I2C_AcknowledgeConfig(I2C1, ENABLE);
I2C_GenerateSTART(I2C1, ENABLE);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
I2C_Send7bitAddress(I2C1, 0xee, I2C_Direction_Transmitter);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2C1, addr);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_Send7bitAddress(I2C1, 0xee, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED)); /* EV7 */
value[0] = I2C_ReceiveData(I2C1);
I2C_AcknowledgeConfig(I2C1, DISABLE);
I2C_GenerateSTOP(I2C1, ENABLE);
value[1] = I2C_ReceiveData(I2C1);
//cal_data = value[0]<<8 | value[1];
//printf("buf[0] = %x,buf[1] = %x,%d,%d\r\n",buf[0],buf[1],(buf[0]<<8|buf[2]),cal_data);
/* Decrement the read bytes counter */
return 0;
在这个函数中也遇到了问题,又是因为复制代码,没有看清楚,误将while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED))写为while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)),导致的问题就是程序一直停在while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)),为什么在这里死循环我还没搞明白。
如果没有出现上述的错误,这时候就可以在main函数里面添加函数read_calibration_data()去读BMP085内部E2PROM的校准数据了
下面整理出最终的代码
uint8_t I2C_Read(I2C_TypeDef *I2Cx,uint8_t I2C_Addr,uint8_t addr,uint8_t *buf,uint16_t num)
if(num==0)
return 1;
while(I2C_GetFlagStatus(I2Cx, I2C_FLAG_BUSY));
I2C_AcknowledgeConfig(I2Cx, ENABLE);
I2C_GenerateSTART(I2Cx, ENABLE);
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_MODE_SELECT));
I2C_Send7bitAddress(I2Cx, I2C_Addr, I2C_Direction_Transmitter);
while (!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
I2C_SendData(I2Cx, addr);
while (!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_Send7bitAddress(I2Cx, I2C_Addr, I2C_Direction_Receiver);
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
while (num)
if(num==1)
I2C_AcknowledgeConfig(I2Cx, DISABLE);
I2C_GenerateSTOP(I2Cx, ENABLE);
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_RECEIVED)); /* EV7 */
*buf = I2C_ReceiveData(I2Cx);
buf++;
num--;
return 0;
uint8_t I2C_Write(I2C_TypeDef *I2Cx,uint8_t I2C_Addr,uint8_t addr,uint8_t value)
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
while(!I2C_CheckEvent(I2Cx, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_SendData(I2Cx, value);
//I2C_delay(200000);//4.5ms
return 0;
