STM32F407的UDP发送数据
STM32F407的UDP发送数据
探究WaveShare的F407的板子好几天了,这两天一直止步于网卡模块的udp发包,因为截包工具总是收不到我代码里面发出去的数据包,我的要求是只发特定数据,不管收到的数据包
记录下整个测试过程,以便以后翻阅
使用开发板自带的例程,udp_echo_server的例子,在此基础上修改,main函数是
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured to
       168 MHz, this is done through SystemInit() function which is called from
       startup file (startup_stm32f4xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f4xx.c file
#ifdef SERIAL_DEBUG
  DebugComPort_Init();
#endif
  /*Initialize LCD and Leds */
  LCD_LED_Init();
  /* configure ethernet */
  ETH_BSP_Config();
  /* Initilaize the LwIP stack */
  LwIP_Init();
  /* UDP echoserver */
  udp_echoserver_init();
  /* Infinite loop */
  while (1)
    /* check if any packet received */
    if (ETH_CheckFrameReceived())
      /* process received ethernet packet */
      LwIP_Pkt_Handle();
    /* handle periodic timers for LwIP */
    LwIP_Periodic_Handle(LocalTime);
我发现串口不能用,可能是其初始化方式有些问题,我做了些修改
将DebugComPort_Init函数改成下面两个函数
  USART_Configuration();
USART_NVIC_Config();
串口1就可以正常使用了
void USART_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  USART_InitTypeDef USART_InitStructure;
  RCC_AHB1PeriphClockCmd(Open_USART_TX_GPIO_CLK,ENABLE);
  RCC_AHB1PeriphClockCmd(Open_USART_RX_GPIO_CLK,ENABLE);
  #ifdef
USART1_OPEN
RCC_APB2PeriphClockCmd(Open_USART_CLK,ENABLE);
  #else
RCC_APB1PeriphClockCmd(Open_USART_CLK,ENABLE);
  #endif
  GPIO_PinAFConfig(Open_USART_TX_GPIO_PORT, Open_USART_TX_SOURCE, Open_USART_TX_AF);
  GPIO_PinAFConfig(Open_USART_RX_GPIO_PORT, Open_USART_RX_SOURCE, Open_USART_RX_AF);
  *  Open_USART_TX -> PA9 , Open_USART_RX -PA10
  GPIO_InitStructure.GPIO_Pin = Open_USART_TX_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(Open_USART_TX_GPIO_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = Open_USART_RX_PIN;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(Open_USART_RX_GPIO_PORT, &GPIO_InitStructure);
USARTx configured as follow:
         - BaudRate = 115200 baud
- Word Length = 8 Bits
         - One Stop Bit
         - No parity
         - Hardware flow control disabled (RTS and CTS signals)
         - Receive and transmit
继承事业,薪火相传
