- //DMA设置
- //启动DMA时钟
- RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
- //DMA通道配置
- DMA_DeInit(DMA2_Stream0);
- DMA_InitStructure.DMA_Channel = DMA_Channel_2;
- //外设地址
- DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&ADC3->DR);
- //内存地址
- DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ADC_Converted_Value;
- //dma传输方向
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
- //设置DMA在传输时缓冲区的长度
- DMA_InitStructure.DMA_BufferSize = LEN_ADC_BUF;
- //设置DMA的外设递增模式,一个外设
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- //设置DMA的内存递增模式
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- //外设数据字长
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- //内存数据字长
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- //设置DMA的传输模式
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
- //设置DMA的优先级别
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- //指定如果FIFO模式或直接模式将用于指定的流:不使能FIFO模式
- DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
- //指定了FIFO阈值水平
- DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
- //指定的Burst转移配置内存传输
- DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
- //指定的Burst转移配置外围转移 */
- DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
- //配置DMA的通道
- DMA_Init(DMA2_Stream0, &DMA_InitStructure);
- //使能通道
- DMA_Cmd(DMA2_Stream0, ENABLE);
- //ADC配置
- //启动ADC时钟
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
- //初始化ADC
- ADC_DeInit();
- //ADC通用配置
- //关闭DMA存取
- ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
- //独立工作模式
- ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
- //分频系数:8,10.5M
- ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8;
- //ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
- //两次采样间隔
- ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
- //ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
- ADC_CommonInit(&ADC_CommonInitStructure);
- //精度为12位
- ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
- //扫描方式
- ADC_InitStructure.ADC_ScanConvMode = ENABLE;
- //ADC_InitStructure.ADC_ScanConvMode = DISABLE;
- //连续转换
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
- //外部触发禁止
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConvEdge_None;
- //数据右对齐
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- //用于转换的通道数
- ADC_InitStructure.ADC_NbrOfConversion = 1;
- ADC_Init(ADC3, &ADC_InitStructure);
- //规则模式通道配置
- ADC_RegularChannelConfig(ADC3, ADC_Channel_9, 1, ADC_SampleTime_144Cycles);
- //ADC_RegularChannelConfig(ADC3, ADC_Channel_9, 1, ADC_SampleTime_15Cycles);
- //使能ADC的DMA
- ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
- ADC_DMACmd(ADC3, ENABLE);
- //使能ADC1
- ADC_Cmd(ADC3, ENABLE);
- //开启ADC1的软件转换
- ADC_SoftwareStartConv(ADC3);
- </pre><br>
