在emwin中显示字库芯片GT23L24M0140的字模(2)
GUI_CharPEx.c
[cpp] view plaincopy
- #include <stddef.h> /* needed for definition of NULL */
- #include "GUI_Private.h"
- //#include "ff.h"
- #include "string.h"
- #include "inf_font.h"
- #include "font_type.h"
- //字模数据的暂存数组,以单个字模的最大字节数为设定值
- #define BYTES_PER_FONT 1024
- static U8 GUI_FontDataBuf[BYTES_PER_FONT];
- ///*字库外部函数部分-----------------------------------------------------------*/
- //void GUI_X_GetFontData(char* font, U32 oft, U8 *ptr, U8 bytes)
- //// FIL fsrc; // 定义文件操作类
- //// FRESULT res; // 定义操作结果变量
- //// UINT br; // 定义读写数量变量
- //// res = f_open(&fsrc, font, FA_OPEN_EXISTING | FA_READ); //打开字库文件
- //// if(res != FR_OK)
- //// res = f_lseek(&fsrc,oft); //找到首地址
- //// res = f_read(&fsrc, ptr, bytes, &br); //读取32个字库点阵数据
- //// res = f_close(&fsrc); //关闭字体
- // //memcpy(ptr,acFontHZ12_b9da1,24);
- // //memcpy(ptr,read_buf,24);
- // bytes = inf_font_read(ASCII_7X8,'j',ptr);
- static
void GUI_GetDataFromMemory(const GUI_FONT_PROP GUI_UNI_PTR *pProp, U16P c) - {
- U16 BytesPerFont;
- U32 oft;
- char *font = (char *)pProp->paCharInfo->pData;
- //汉字正序
- uint8_t c1 = c >> 8;
- uint8_t c2 = c;
- uint16_t c3 = (c2 << 8) + c1;
- BytesPerFont = GUI_pContext->pAFont->YSize * pProp->paCharInfo->BytesPerLine; //每个字模的数据字节数
- if (BytesPerFont > BYTES_PER_FONT)
- {BytesPerFont = BYTES_PER_FONT;}
- if (c < 0x80) //英文字符地址偏移算法
- oft = (c-0x20) * BytesPerFont;
- BytesPerFont = inf_font_read(Font_Now,c,GUI_FontDataBuf);
- else
- oft = ((((c >> 8)-0xA1)) + ((c & 0xFF)-0xb0) * 94)* BytesPerFont; //中文字符地址偏移算法包括符号
- BytesPerFont = inf_font_read(Font_Now,c3,GUI_FontDataBuf);
- // if (strncmp(FontEx_HZ,font,sizeof(FontEx_HZ)) == 0)
- //GUI_X_GetFontData(font, oft, GUI_FontDataBuf, BytesPerFont);
- // BytesPerFont = inf_font_read(Font_Now,c,GUI_FontDataBuf);
- void GUIPROP_X_DispChar(U16P c)
- int BytesPerLine;
- GUI_DRAWMODE DrawMode = GUI_pContext->TextMode;
- const GUI_FONT_PROP GUI_UNI_PTR *pProp = GUI_pContext->pAFont->p.pProp;
- //搜索定位字库数据信息
- for (; pProp; pProp = pProp->pNext)
- if ((c >= pProp->First) && (c <= pProp->Last))break;
- if (pProp)
- GUI_DRAWMODE OldDrawMode;
- const GUI_CHARINFO GUI_UNI_PTR * pCharInfo = pProp->paCharInfo;
- GUI_GetDataFromMemory(pProp, c);//取出字模数据
- BytesPerLine = pCharInfo->BytesPerLine;
- OldDrawMode = LCD_SetDrawMode(DrawMode);
- LCD_DrawBitmap(GUI_pContext->DispPosX, GUI_pContext->DispPosY,
- pCharInfo->XSize, GUI_pContext->pAFont->YSize,
- GUI_pContext->pAFont->XMag, GUI_pContext->pAFont->YMag,
- 1, /* Bits per Pixel */
- BytesPerLine,
- &GUI_FontDataBuf[0],
- &LCD_BKCOLORINDEX
- /* Fill empty pixel lines */
- if (GUI_pContext->pAFont->YDist > GUI_pContext->pAFont->YSize)
- int YMag = GUI_pContext->pAFont->YMag;
- int YDist = GUI_pContext->pAFont->YDist * YMag;
- int YSize = GUI_pContext->pAFont->YSize * YMag;
- if (DrawMode != LCD_DRAWMODE_TRANS)
- LCD_COLOR OldColor = GUI_GetColor();
- GUI_SetColor(GUI_GetBkColor());
- LCD_FillRect(GUI_pContext->DispPosX, GUI_pContext->DispPosY + YSize,
- GUI_pContext->DispPosX + pCharInfo->XSize,
- GUI_pContext->DispPosY + YDist);
- GUI_SetColor(OldColor);
- LCD_SetDrawMode(OldDrawMode); /* Restore draw mode */
- GUI_pContext->DispPosX += pCharInfo->XDist * GUI_pContext->pAFont->XMag;
- * GUIPROP_GetCharDistX
- int GUIPROP_X_GetCharDistX(U16P c)
- const GUI_FONT_PROP GUI_UNI_PTR * pProp = GUI_pContext->pAFont->p.pProp;
- return (pProp) ? (pProp->paCharInfo)->XSize * GUI_pContext->pAFont->XMag : 0;
