STM32产生SPWM
STM32产生SPWM
  • /** @author Mei Jilin
  •     @date   2013/9/2
  •     @brief  加入生成SPWM部分
  • #include "timer.h"
  • #include "led.h"
  • static uint16_t CCR3_Val = 1800;
  • static uint16_t PrescalerValue = 0;
  • /*PWM输出配置说明,*/
  • /* - Prescaler = (TIM3CLK / TIM3 counter clock) - 1 选择TIMER工作在36MHZ
  •     The TIM3 is running at 36 MHz: TIM3 Frequency = TIM3 counter clock/(ARR + 1)
  •                                                   = 36 MHz / 3600 = 10 KHz
  •     TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 */
  •     /*转换周期10K*/
  • void PWM_Init(void)
  •     TIM_TimeBaseInitTypeDef     TIM_TimeBaseStructure;
  •     TIM_OCInitTypeDef           TIM_OCInitStructure;
  •     GPIO_InitTypeDef            GPIO_InitStructure;
  •     NVIC_InitTypeDef NVIC_InitStructure;
  •         /* TIM3 clock enable */
  •     RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
  •     /* GPIOA and GPIOB clock enable */
  •     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|
  •                              RCC_APB2Periph_AFIO, ENABLE);
  •     /* GPIOA Configuration:TIM3 Channel1, 2, 3 and 4 as alternate function push-pull */
  •     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  •     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  •     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •     GPIO_Init(GPIOA, &GPIO_InitStructure);
  •     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;      //TIM1_CH1N
  •     GPIO_Init(GPIOB, &GPIO_InitStructure);
  •      /* Compute the prescaler value */
  •     PrescalerValue = (uint16_t) (SystemCoreClock / 36000000) - 1; //TIMER2 - 36MHZ
  •     /* Time base configuration */
  •     TIM_TimeBaseStructure.TIM_Period = 3600;                    /*TIM3_ARR = 2879,12.5Khz*/
  •     TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  •     TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  •     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  •     TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  •     TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  •     /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  •     TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  •     TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  •     TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable; //关闭互补输出
  •     TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
  •     TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  •     TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  •     TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  •     TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Set;
  •     TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  •     TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //这句的功能是让改变CCR2之后马上有效
  •     TIM_ITConfig(TIM1, TIM_IT_CC1, ENABLE);
  •     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  •     NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;
  •     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  •     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 6;
  •     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  •     NVIC_Init(&NVIC_InitStructure);
  •     TIM_Cmd(TIM1, ENABLE);
  •     /* TIM1 Main Output Enable */
  •     TIM_CtrlPWMOutputs(TIM1, ENABLE);   //TIM1需要加上这句,貌似低级定时器不需要
  • uint16_t Duty[] = {1800,1856,1912,1968,2023,2078,2131,2183,2233,2282,2329,2373,2416,2456,2493,
  •     2528,2559,2588,2614,2636,2655,2671,2684,2692,2698,2699,2698,2692,2684,2671,2655,2636,2614,
  •     2588,2559,2528,2493,2456,2416,2373,2329,2282,2233,2183,2131,2078,2023,1968,1912,1856,1800,
  •     1743,1687,1631,1576,1521,1468,1416,1366,1317,1270,1226,1183,1143,1106,1071,1040,1011,985,
  •     963,944,928,915,907,901,900,901,907,915,928,944,963,985,1011,1040,1071,1106,1143,1183,1226,
  •     1270,1317,1366,1416,1468,1521,1576,1631,1687,1743,1799,1799};
  • uint16_t count = 0;
  • uint16_t num = sizeof(Duty)/(sizeof(Duty[0]));
  • void TIM1_CC_IRQHandler(void)
  •   if (TIM_GetITStatus(TIM1, TIM_IT_CC1) != RESET)
  •     TIM1->SR = (uint16_t)~TIM_IT_CC1;
  •     TIM1->CCR1 = Duty[count];
  •     count++;
  •     if(count==num)
  •         count=0;
继承事业,薪火相传
