一直对STM8S的硬件SPI感兴趣,但没有真正使用过,以往都是用IO口模拟,这次刚好有个板子上有两个595驱动的8位LED数码管,就在上面试了一把,把过程记录一下。硬件接线图:
<IMG title="STM8S 硬件SPI驱动74HC595" name=image_operate_78821400644628923 alt="STM8S 硬件SPI驱动74HC595" src="http://s16.sinaimg.cn/mw690/002zvrWDgy6J2Ytnve77f&690" real_src="http://s16.sinaimg.cn/mw690/002zvrWDgy6J2Ytnve77f&690">
595是数据接收器件,所以MCU只用了3条线与之相连,分别是MOSI接SER,SCK接CLK,NSS接RCK。其实这里RCK可以用其他的IO口的。
相关的代码:
LOCAL uint8 DISP_BUF[8]={0,1,2,3,4,5,6,7}; //显示缓冲区
PUBLIC uint8 DISP_TAB[]= //显示码表
0x14,0xD7,0x4C,0x45,0x87,0x25,0x24,0x57,0x04,0x05,0x06,0xA4,0x3C
相关的IO口设为上拉输出
LOCAL void gpio_init(void)
GPIO_DeInit(GPIOC);
GPIO_Init(GPIOC,GPIO_PIN_5|GPIO_PIN_6,GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_DeInit(GPIOE);
GPIO_Init(GPIOE,GPIO_PIN_5,GPIO_MODE_OUT_PP_LOW_FAST);
SPI初始化
LOCAL void spi_init(void)
SPI_DeInit();
CLK_PeripheralClockConfig(CLK_PERIPHERAL_SPI, ENABLE);
SPI_Init(SPI_FIRSTBIT_LSB, SPI_BAUDRATEPRESCALER_256, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_LOW, SPI_CLOCKPHASE_1EDGE, SPI_DATADIRECTION_1LINE_TX, SPI_NSS_SOFT, 0x07);
SPI_Cmd(ENABLE);
显示程序
PUBLIC void DISP_Display(void)
uint8 i,dig = 0x80;
for (i=0;i<8;i++)
GPIO_WriteLow(GPIOE,GPIO_PIN_5);
while (SPI_GetFlagStatus(SPI_FLAG_TXE) == RESET);
SPI_SendData(DISP_TAB[DISP_BUF]);
SPI_SendData(dig);
GPIO_WriteHigh(GPIOE,GPIO_PIN_5);
delay(20);
dig >>= 1;
编译运行,出现的字符如下:
<IMG title="STM8S 硬件SPI驱动74HC595" name=image_operate_11231400644658991 alt="STM8S 硬件SPI驱动74HC595" src="http://s6.sinaimg.cn/mw690/002zvrWDgy6J2YyIdXnd5&690" real_src="http://s6.sinaimg.cn/mw690/002zvrWDgy6J2YyIdXnd5&690">
用示波器看了下,MOSI脚和SCK脚的波形正常。猜想是硬件SPI的速度太快,595跟不上。于是修改代码,在两次发送数据之后都延时一下。
uint8 i,dig = 0x80;
for (i=0;i<8;i++)
delay(500);
SPI_SendData(dig);
delay(500);
delay(20);
dig >>= 1;
再次编译运行,显示如下:
<IMG title="STM8S 硬件SPI驱动74HC595" name=image_operate_52611400644673556 alt="STM8S 硬件SPI驱动74HC595" src="http://s6.sinaimg.cn/mw690/002zvrWDgy6J2YzQZ7fc5&690" real_src="http://s6.sinaimg.cn/mw690/002zvrWDgy6J2YzQZ7fc5&690">
结论:
1. STM8S 硬件SPI的速度较快,实际应用的时候需要考虑外部设备的响应速度问题。
2. while (SPI_GetFlagStatus(SPI_FLAG_TXE) == RESET);只能保证每次SPI发送数据前,发送缓冲区是空的,即上次数据已经发送完成,但不能保证外部设备正确接收了数据。 |
