STM32的SPI查询方式传输测试
STM32的SPI查询方式传输测试
环境:
主机:WIN7
开发环境:MDK4.23
MCU:STM32F103CBT6
说明:
软件设置NSS脚,利用查询方式传输
源代码:
初始化代码:
[cpp] view plaincopy
  • //关闭SPI
  • SPI_Cmd(SPI1,DISABLE);
  • //初始化SPI接口的SSN脚以及NTRX的RST脚
  • NtrxCtrlInit();
  • //初始化SPI时钟
  • RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1 | RCC_APB2Periph_GPIOA,ENABLE);
  • //配置SPI1引脚:SCK, MISO and MOSI
  • GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
  • GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP ;
  • GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz ;
  • GPIO_Init( GPIOA, &GPIO_InitStructure );
  • // SPI1配置
  • SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex ;
  • SPI_InitStructure.SPI_Mode = SPI_Mode_Master ;
  • SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b ;
  • SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low ;
  • SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge ;
  • SPI_InitStructure.SPI_NSS = SPI_NSS_Soft ;
  • //SPI波特率分频设置:4M
  • SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8 ;
  • //SPI设置成LSB模式
  • SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_LSB ;
  • SPI_InitStructure.SPI_CRCPolynomial = 7 ;
  • SPI_Init( SPI1, &SPI_InitStructure ) ;
  • //启动SPI
  • SPI_Cmd(SPI1,ENABLE);
发送代码:
  • //SPI发送一个字节
  • static uint8 SPI_SendByte(uint8 Data)
  •     // Loop while DR register in not emplty
  •     while( SPI_I2S_GetFlagStatus( SPI1, SPI_I2S_FLAG_TXE ) == RESET ) ;
  •     // Send byte through the SPI1 peripheral
  •     SPI_I2S_SendData( SPI1, Data ) ;
  •     // Wait to receive a byte
  •     while( SPI_I2S_GetFlagStatus( SPI1, SPI_I2S_FLAG_RXNE ) == RESET ) ;
  •     // Return the byte read from the SPI bus
  •     return SPI_I2S_ReceiveData( SPI1 ) ;
接收代码:
  • //SPI读取一个字节
  • void SPI_ReadBytes( uint8 Addr, NtrxBufferPtr Buffer, uint8 Len )
  •     if( ( Len > 0x80 ) || ( Len == 0 ) )
  •         Len = 1 ;
  •     SPI_SendByte( Len ) ;
  •     SPI_SendByte( Addr ) ;
  •     while( Len-- )
  •         *Buffer = SPI_SendByte( 0xFF ) ;
  •         Buffer ++ ;
NSS脚电平设置:
  • //SSN脚拉低,开始发送数据
  • void NtrxSSN_Lo( void )
  •     GPIO_ResetBits( NTRX_SSN_PORT, NTRX_SSN_PIN ) ;
  • //SSN脚置高,结束发送数据
  • void NtrxSSN_Hi( void )
  •     GPIO_SetBits( NTRX_SSN_PORT, NTRX_SSN_PIN ) ;
示例代码:
  • uint8 NtrxReadSingleSPI( uint8 Addr )
  •     NtrxBufferType r ;
  •     NtrxSSN_Lo() ;
  •     SPI_ReadBytes( Addr, &r, 1 ) ;
  •     NtrxSSN_Hi() ;
  •     return r ;
继承事业,薪火相传
