ULN2803中文资料
ULN2803中文资料
ULN2802 ULN2803 ULN2804A 8个NPN达林顿晶体管,连接在阵列非常适合逻辑接口电平数字电路(例如TTL,CMOS或PMOS上/ NMOS)和较高的电流/电压,如电灯,电磁阀,继电器,打印锤或其他类似的负载,广泛的使用范围:计算机,工业和消费应用。所有设备功能由集电极输出和钳位二极管瞬态抑制。该ULN2803是专为符合标准TTL,而制造ULN2804适合6至15V的高级别CMOS或PMOS上。该电路为反向输出型,即输入低电平电压,输出端才能导通工作。
                                         图一 引脚
1-8引脚:输入端
11-18引脚:输出端
9引脚:地端
10引脚:电源+
     图二 ULN2803内部电路图 (1/8单元)                        图二 ULN2804内部电路图 (1/8单元)
MAXIMUM RATINGS (TA = 25℃ and rating apply to any one device in the
package, unless otherwise noted.)最大额定值
Rating 参数Symbol 符号Value 数值Unit 单位
Outputvoltage 输出电压VO 50 V
Inputvoltage (Except ULN2801) 输入电压(除ULN2801 )VI 30 V
Collector Current – Continuous 集电极电流-连续IC 500 mA
Base Current – Continuous 基极电流-连续IB 25 mA
Operating Ambient Temperature Range 操作环境温度范围TA 0 to +70
Storage Temperature Range 储存温度范围Tstg 55 to +150
Junction Temperature 结温TJ  125
订购信息
Device
Characteristics
Input Compatibility 输入兼容性VCE(Max)/IC(Max) Operating Temperature Range工作温度范围
ULN2803A ULN2804A TTL,5.0v CMOS 6to15v CMOS,PMOS 50v/500mATA=0 to + 70℃
ELECTRICAL CHARACTERISTICS (TA = 25℃, unless otherwise noted)电气特性:
Characteristic 参数符号 最小 典型最大Unit单位
Output Leakage Current (Figure 1)输出泄漏电流(图1 )μA
(VO = 50v, TA = +70℃) 所有类型ICEX  100
(VO = 50v, TA = +25℃) 所有类型  50
(VO = 50v, TA = +70℃,vI = 6.0V)  ULN2802   500
(VO = 50v, TA = +70℃,vI = 1.0V)ULN2804   500
Collector–Emitter Saturationvoltage (Figure 2)集电极发射极饱和电压(图2 ) V
(IC = 350mA, IB = 500μA) 所有类型VCE(sat)  1.1  1.6
(IC = 200mA, IB = 350μA) 所有类型  0.951.3
(IC = 100mA, IB = 250μA) 所有类型  0.85 1.1
Input Current – On Condition (Figure 4)  输入电流-状态(图4 )mA
(VI = 17v)ULN2802II(on)  0.82  1.25
(VI = 3.85v) ULN2803 0.931.35
(VI = 5.0v)  ULN2804 0.35 0.5
(VI = 12v)ULN2804 1.0 1.45
Inputvoltage – On Condition (Figure 5) 输入电压-状态(图5 )V
(VCE = 2.0v, IC = 300mA) ULN2802VI(on)   13
(VCE = 2.0v, IC = 200mA) ULN2803  2.4
(VCE = 2.0v, IC = 250mA) ULN2803  2.7
(VCE = 2.0v, IC = 300mA) ULN2803  3.0
(VCE = 2.0v, IC = 125mA) ULN2804   5.0
(VCE = 2.0v, IC = 200mA) ULN2804  6.0
(VCE = 2.0v, IC = 275mA) ULN2804  7.0
(VCE = 2.0v, IC = 350mA) ULN2804   8.0
Input Current–Off Condition 输入电流开关条件(Figure3)(IC= 500mA,TA=+70℃) 所有类型 II(off) 50 100 μA
DC Current Gain (Figure 2)直流电流增益(VCE=2.0v, IC=350mA) ULN2801 hFE 1000
Input Capacitance 输入电容CI 15 25 pF
Turn–On Delay Time 开启延迟时间(50% EI to 50% EO) ton 0.25 1.0 μs
Turn–Off Delay Time 关断延迟时间(50% EI to 50% EO) toff 0.25 1.0 μs
Clamp Diode Leakage Current (Figure 6)钳位二极管漏电流(VR=50v) TA = +25℃IR 50  μA
TA = +70℃ 100
Clamp Diode Forwardvoltage(Figure 7)钳位二极管正向电压(IF=350mA) VF 1.5 2.0 V
测试图:
                  图1        图2
             图3        图4
                   图5        图6
                  图7
                               图四 封装图
应用电路图:
                                图五 步进电机驱动器
                                    图六 二相步进电机驱动器
                                         图七 LED发光二极管驱动器电路
另外w
ULN2803和2003没有多大其别,他们都是最高承受电压50V,最大电流500MA,只是2803是8通道,2003是7通道,
2803比2003多了一个通道。
