STM32-移植FATFS的NANDFLASH驱动(4)
- * @brief Reads NAND memory's ID.
- * @param NAND_ID: pointer to a NAND_IDTypeDef structure which will hold
- * the Manufacturer and Device ID.
- * @retval : None
- void FSMC_NAND_ReadID(NAND_IDTypeDef* NAND_ID)
- uint32_t data = 0;
- /* Send Command to the command area */
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READID;
- /* Send Address to the address area */
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = NAND_CMD_IDADDR;
- /* Sequence to read ID from NAND flash */
- data = *(__IO uint32_t *)(Bank_NAND_ADDR | DATA_AREA);
- NAND_ID->Maker_ID = DATA_1st_CYCLE (data);
- NAND_ID->Device_ID = DATA_2nd_CYCLE (data);
- NAND_ID->Third_ID = DATA_3rd_CYCLE (data);
- NAND_ID->Fourth_ID = DATA_4th_CYCLE (data);
- * @brief This routine is for move one 2048 Bytes Page size to an other 2048 Bytes Page.
- * the copy-back program is permitted just between odd address pages or even address pages.
- * @param SourcePageAddress: Source page address
- * @param TargetPageAddress: Target page address
- * @retval : New status of the NAND operation. This parameter can be:
- * - NAND_TIMEOUT_ERROR: when the previous operation generate
- * a Timeout error
- * - NAND_READY: when memory is ready for the next operation
- * And the new status of the increment address operation. It can be:
- * - NAND_VALID_ADDRESS: When the new address is valid address
- * - NAND_INVALID_ADDRESS: When the new address is invalid address
- uint32_t FSMC_NAND_MoveSmallPage(uint32_t SourcePageAddress, uint32_t TargetPageAddress)
- uint32_t status = NAND_READY ;
- uint32_t data = 0xff;
- /* Page write command and address */
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_MOVE0;
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(SourcePageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(SourcePageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(SourcePageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_4th_CYCLE(SourcePageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_MOVE1;
- while( GPIO_ReadInputDataBit(GPIOG, GPIO_Pin_6) == 0 );
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_MOVE2;
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(TargetPageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(TargetPageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(TargetPageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_4th_CYCLE(TargetPageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_MOVE3;
- /* Check status for successful operation */
- status = FSMC_NAND_GetStatus();
- data = *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA);
- if(!(data&0x1)) status = NAND_READY;
- return (status);
- * @brief This routine is for writing one or several 2048 Bytes Page size.
- * @param pBuffer: pointer on the Buffer containing data to be written
- * @param PageAddress: First page address
- * @param NumPageToWrite: Number of page to write
- * a Timeout error
- uint32_t FSMC_NAND_WriteSmallPage(uint8_t *pBuffer, uint32_t PageAddress, uint32_t NumPageToWrite)
- uint32_t index = 0x00, numpagewritten = 0x00,addressstatus = NAND_VALID_ADDRESS;
- uint32_t status = NAND_READY, size = 0x00;
- while((NumPageToWrite != 0x00) && (addressstatus == NAND_VALID_ADDRESS) && (status == NAND_READY))
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE0;
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(PageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(PageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(PageAddress);
- *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_4th_CYCLE(PageAddress);
- /* Calculate the size */
- size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpagewritten);
- /* Write data */
- for(; index < size; index++)
- *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE1;
- if(status == NAND_READY)
- numpagewritten++; NumPageToWrite--;
- /* Calculate Next small page Address */
- if(PageAddress++ > (NAND_MAX_ZONE*NAND_ZONE_SIZE*NAND_BLOCK_SIZE))
- { addressstatus = NAND_INVALID_ADDRESS;}
- return (status | addressstatus);
- * @brief This routine is for sequential read from one or several
- * 2048 Bytes Page size.
- * @param pBuffer: pointer on the Buffer to fill
- * @param NumPageToRead: Number of page to read
- * a Timeout error
- uint32_t FSMC_NAND_ReadSmallPage(uint8_t *pBuffer, uint32_t PageAddress, uint32_t NumPageToRead)
- uint32_t index = 0x00, numpageread = 0x00, addressstatus = NAND_VALID_ADDRESS;
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ1;
- while((NumPageToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
- /* Page Read command and page address */
- *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ2;
- size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpageread);
- /* Get Data into Buffer */
- pBuffer[index]= *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA);
- numpageread++; NumPageToRead--;
- /* Calculate page address */
