STM32——USB详细使用说明(9)
STM32——USB详细使用说明(9)
uint8_tIn0_Process(void)
  uint32_t ControlState =pInformation->ControlState;
  if ((ControlState == IN_DATA)|| (ControlState == LAST_IN_DATA))  //控制状态
   DataStageIn();//第一次取设备描述符只取一次 当前的状态变为WAIT_STATUS_IN 表明设备等待状态过程主机输出0字节
    ControlState= pInformation->ControlState;
  else if (ControlState ==WAIT_STATUS_IN)       //设置地址状态阶段进入这个程序
    if((pInformation->USBbRequest == SET_ADDRESS)&&
       (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT)))
     SetDeviceAddress(pInformation->USBwValue0);
//设置使用新的地址
     pUser_Standard_Requests->User_SetDeviceAddress();
   (*pProperty->Process_Status_IN)();
   ControlState=STALLED;                  //终止发送和接受
  else
    ControlState= STALLED;
pInformation->ControlState =ControlState;
  return Post0_Process();
uint8_t Post0_Process(void)
#ifdef STM32F10X_CL
  USB_OTG_EP *ep;
#endif
  SetEPRxCount(ENDP0,Device_Property.MaxPacketSize);  //设置端点0 要接受的字节数
  if(pInformation->ControlState ==STALLED)           //这种状态下只接受SETUP命令包
   vSetEPRxStatus(EP_RX_STALL);
//终止端点0接受
   vSetEPTxStatus(EP_TX_STALL);                      //终止端点0发送
  return(pInformation->ControlState ==PAUSE);
***************(6)*************
从新地址获取设备描述符
继承事业,薪火相传
